2811 Flash Memory
mchiaravalle_2
Level 3
Level 3
I know the corporate answer on this but I thought I'd toss this out. Has anyone used non-Cisco flash in any of the 2800 series routers before? I'm using 2811s for my remote site access routers and I want to upgrade the flash to 128MB
I realize that if I contact TAC they may not support.
I'm finding it hard to spend $500-$700 for a 128MB CF when I can get the best name brand for less than 1/5 the cost.
We use 3rd party CF all the time for upgrades. Very little issues if any - no more issues than with the Cisco branded CF!
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
8 Replies 8
JORGE RODRIGUEZ
Level 11
Level 11
I check with our cisco vendor provider, you may find new MEM2800-128CF cisco compatible for as low as $200.
http://www.dexon.com is an authorized cisco reseller, I have been buying cisco from them for about 6 years and have had no complains. In addition, they provide one year warranty
for any cisco equipement.
Jorge
Jorge Rodriguez
ccbootcamp
Level 10
Level 10
Just send an email to Jason at computer parts now:
jason@computerpartsnow.com
He has the best memory pricing around.
or go to:
http://www.memoryx.net/ci28rorflme1.html
128MB CF flash for $50.
-brad
www.ccbootcamp.com
indeed $50 great price ! can't beat that!
Jorge Rodriguez
2 snaps for that! I remember when 8mb flash for the 2500 series router was $200+/stick! Ah, the good 'ole days.
-brad
www.ccbootcamp.com
OK, thanks.
I was doing some web searching before my original post, that's how I found out about the cheaper alternatives. I was mainly looking for any info on reliability issues.
-brad
www.ccbootcamp.com
Good thanks.
sales
Level 2
Level 2
http://simondirect.com/store/index.php?main_page=index&cPath=7_27
MEM2811-256D $96 Cisco Approved
256MB DRAM MODULE Cisco Approved Memory For Cisco Router 2811 MEM2811-256D= MEM2811-256U512D MEM2811-256U512D= MEM2811-256U512D
MAIN CISCO DRAM MEMORY
Maximum Memory: 768mb
Base Memory: 256mb (Non removable)
Upgrade Sockets: 1 (1 bank of 1)
CISCO FLASH MEMORY
Maximum Memory: 256mb
Base Memory: 64mb (Removable)
