2851 Router not recognizing EtherSwitch module NME-XD-48ES-2S-P
Grant Serbousek
For my home lab, I just purchased the above referenced EtherSwitch module.  I get this pertaining to the card on boot:
Press RETURN to get started!
*Oct 14 14:58:22.307: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 65535)) is not supported on this image.
           Please issue "show diag" in fully loaded IOS image
           to get the PA's information and verify if it is supported
           by this image, a newer version may be needed.
Other info:
BSMT2851#sho diag
Slot 0:
        C2851 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 00:04:02 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC12242YNK
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26922-03
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20080612
        Chassis Serial Number    : FTX1226A1RJ
        Chassis MAC Address      : 0021.d826.9be0
        MAC Address block size   : 32
        CLEI Code                : COM7N00ARA
        Product (FRU) Number     : CISCO2851
        Part Number              : 73-8480-05
        Version Identifier       : V04
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 32 32 34 32 59 4E 4B 40
          0x10: 03 E9 41 01 00 C0 46 03 20 00 69 2A 03 42 41 30
          0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 67 E4 C2 8B 46 54 58 31 32 32 36
          0x40: 41 31 52 4A C3 06 00 21 D8 26 9B E0 43 00 20 C6
          0x50: 8A 43 4F 4D 37 4E 30 30 41 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 35 31 20 20 20 20 20 20 82 49 21 20
          0x70: 05 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
Slot 1:
        Unknown (type 65535) Port adapter
        Port adapter is disabled
        Port adapter insertion time unknown
        EEPROM format version 255
          0x00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
BSMT2851#sho ip int brief (**note missing GigabitEthernet1/0** - which is what the EtherSwitch card would show up as if recognized)
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         10.255.255.2    YES NVRAM  up                    up
GigabitEthernet0/1         10.20.30.2      YES NVRAM  up                    up
Virtual-Access1            unassigned      YES unset  down                  down
Virtual-Template1          unassigned      YES NVRAM  down                  down
Loopback254                10.1.254.2      YES NVRAM  up                    up
Loopback255                10.255.255.254  YES NVRAM  up                    up
BSMT2851#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(3)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 24-May-12 01:38 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
BSMT2851 uptime is 1 minute
System image file is "flash:c2800nm-advipservicesk9-mz.151-3.T4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2851 (revision 53.51) with 1036288K/12288K bytes of memory.
Processor board ID FTX1226A1RJ
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
239K bytes of non-volatile configuration memory.
253008K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2851 FTX1226A1RJ
**I also have tried IOS 12.4T with image file "c2800nm-ipbase-mz.124-25f.bin"
I've looked at the following resources and performed the hardware installation verbatim according to the guide:
http://docstore.mik.ua/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/wic_inst/wic_doc/vwicpdf.pdf
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/network-modules/82288-es-mod-config.html?referring_site=RE&pos=1&page=http://www.cisco.com/c/en/us/products/collateral/routers/3800-series-integrated-services-routers-isr/product_data_sheet...
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/interface-cards/71820-routermodules.html
anyone have suggestions on where to go from here?  I reseated the card and looked at the connectors and everything looks good and doesn't smell like fried electronics.  No LEDs or lights on the EtherSwitch card.
Thanks!
UPDATE:  I noticed that I have 1 DIMM slot filled with ECC RAM, and 1 DIMM slot with non-ECC RAM.  IOS has thus disabled ECC RAM usage on this platform.  Thoughts on this interaction with the EtherSwitch?
6 Replies 6
Leo Laohoo
Console into the router and reboot the router.  I want to see the entire boot-up sequence.
I have a funny feeling it's due to the "T" train IOS that's causing the issue.  Try using an "M" train of any 15.X version and see if there are any improvements.
Here we go.  This is how honest I am, I pasted the two startups both from a "T" train IOS and an "M" train IOS including my screwup when I didn't state the disk for the new boot statement.  Please note that the vendor I purchased the NME-XD-48 EtherSwitch module from was using the 15.1 "T" train series IOS to test with successfully the unit before shipment.
I thank you sincerely for taking the time to review my issues and help, It is an investment for me personally to purchase this item, so I need it to work.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.10.14 20:04:13 =~=~=~=~=~=~=~=~=~=~=~=
BSMT2851#reload      sho riun     un | i             reload
System configuration has been modified. Save? [yes/no]:
Oct 14 2016 20:04:34.603 EDT: %AAA-3-BADSERVERTYPEERROR: Cannot process accounting server type tacacs+ (UNKNOWN)
q
% Please answer 'yes' or 'no'.
System configuration has been modified. Save? [yes/no]: no
Proceed with reload? [confirm]^C
BSMT2851#sho run
BSMT2851#sho running-config
Building configuration...
Current configuration : 12333 bytes
! Last configuration change at 18:15:55 EDT Fri Oct 14 2016 by admin
version 15.1
service tcp-keepalives-in
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
hostname BSMT2851
boot-start-marker
boot system flash c2800nm-spservicesk9-mz.151-3.T4.bin
boot-end-marker
logging buffered 50000
enable secret 5 $1$qF8F$/zhu6bK4RTf4DREFoLhMq/
aaa new-model
 --More--
BSMT2851#wr
[OK]
BSMT2851#reload
Oct 14 2016 20:05:09.116 EDT: %SYS-5-RELOAD: Reload requested by admin on console. Reload Reason: Reload Command.
Copyright (c) 2009 by cisco Systems, Inc.
Memory Dimms are not of the same type
DIMM0 is a ECC Memory
DIMM1 is a non-ECC Memory
c2851 platform with 1048576 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC disabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x3749740
Self decompressing the image : ######################################################################################################################################################################################################################################################################################################################################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
0003E9          0X00474800 C2851 Mainboard
00FFFF           UNKNOWN port adapter
                0X000021B8 Onboard USB
                0X002C29F0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X0094A3A8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 10Mb.
Using 0 percent iomem. [10Mb/1024Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 15.1(3)T4, RELEASE SOFTWARE (fc1)
export@cisco.com.
Cisco 2851 (revision 52.57) with 1038336K/10240K bytes of memory.
Kron: Policy Accepted, Policy configbackup needs to be configured
Kron: Policy Accepted, Policy clearallsshvty needs to be configured
Warning: flash:P0S3-07-5-00 does not exist.  Command retained.
Warning: flash:P0S3-07-5-00.loads does not exist.  Command retained.
Warning: flash:P0S3-07-5-00.bin does not exist.  Command retained.
Warning: flash:P0S3-07-5-00.sb2 does not exist.  Command retained.
Warning: flash:P003-07-5-00.bin does not exist.  Command retained.
Warning: flash:P003-07-5-00.sbn does not exist.  Command retained.
Warning: flash:apps45.9-4-2ES9.sbn does not exist.  Command retained.
Warning: flash:cnu45.9-4-2ES9.sbn does not exist.  Command retained.
Warning: flash:cvm45sccp.9-4-2ES9.sbn does not exist.  Command retained.
Warning: flash:dsp45.9-4-2ES9.sbn does not exist.  Command retained.
Warning: flash:jar45sccp.9-4-2ES9.sbn does not exist.  Command retained.
Warning: flash:SCCP45.9-4-2SR1-1S.loads does not exist.  Command retained.
Warning: flash:term45.default.loads does not exist.  Command retained.
Warning: flash:term65.default.loads does not exist.  Command retained.
Warning: flash:/* does not exist.  Command retained.propagate phone type from 'ephone-template 1' to 'ephone 1'
CNF file update complete for phone-1
propagate phone type from 'ephone-template 2' to 'ephone 3'
CNF file update complete for phone-3
propagate phone type from 'ephone-template 2' to 'ephone 4'
CNF file update complete for phone-4
!!Following voice command is enabled:                    !!
!!  voice service voip                                   !!
!!   ip address trusted authenticate                     !!
!!The command enables the ip address authentication      !!
!!on incoming H.323 or SIP trunk calls for toll fraud    !!
!!prevention supports.                                   !!
!!Please use "show ip address trusted list" command      !!
!!to display a list of valid ip addresses for incoming   !!
!!H.323 or SIP trunk calls.                              !!
!!Additional valid ip addresses can be added via the     !!
!!following command line:                                !!
!!   ip address trusted list                             !!
!!    ipv4 <ipv4-address> [<ipv4 network-mask>]          !!
*Oct 15 00:48:03.443: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 65535)) is not supported on this image.
*Oct 15 00:48:08.023: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Oct 15 00:48:08.023: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Oct 15 00:48:08.023: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Oct 15 00:48:09.207: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
*Oct 15 00:48:09.207: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Oct 14 2016 19:48:09.915 EST: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:48:09 UTC Sat Oct 15 2016 to 19:48:09 EST Fri Oct 14 2016, configured from consol
CNF-FILES: Clock is not set or synchronized, retaining old vere by console.
*Oct 14 2016 20:48:09.915 EDT: %SYS-6-CLOCKUPDATE: System clock has been updated from 19:48:09 EST Fri Oct 14 2016 to 20:48:09 EDT Fri Oct 14 2016, configured from console by console.
*Oct 14 2016 20:48:11.043 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback254, changed state to up
*Oct 14 2016 20:48:11.043 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback255, changed state to up
*Oct 14 2016 20:48:11.631 EDT: CEF-HWIDB: EDSP0 LES switching vector set to Null
*Oct 14 2016 20:48:11.631 EDT: CEF-HWIDB: EDSP0 LES switching vector set to CEF switching
*Oct 14 2016 20:48:11.635 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0 added.
*Oct 14 2016 20:48:12.219 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.1 added.
*Oct 14 2016 20:48:12.223 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.2 added.
*Oct 14 2016 20:48:12.223 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.3 added.
*Oct 14 2016 20:48:12.223 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.4 added.
*Oct 14 2016 20:48:12.223 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.5 added.
*Oct 14 2016 20:48:12.359 EDT: %LINK-3-UPDOWN: Interface ephone_dsp DN 1.1, changed state to up
*Oct 14 2016 20:48:12.359 EDT: %LINK-3-UPDOWN: Interface ephone_dsp DN 1.2, changed state to up
*Oct 14 2016 20:48:12.367 EDT: %LINK-3-UPDOWN: Interface ephone_dsp DN 2.1, changed state to up
*Oct 14 2016 20:48:12.799 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface EDSP0, changed state to up
*Oct 14 2016 20:48:12.883 EDT: %SYS-5-CONFIG_I: Configured from memory by console
*Oct 14 2016 20:48:13.231 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Oct 14 2016 20:48:13.235 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Oct 14 2016 20:48:14.503 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
*Oct 14 2016 20:48:14.503 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Oct 14 2016 20:48:17.519 EDT: %SYS-5-RESTART: System restarted --
*Oct 14 2016 20:48:17.523 EDT: %SNMP-5-COLDSTART: SNMP agent on host BSMT2851 is undergoing a cold start
*Oct 14 2016 20:48:17.735 EDT: %SYS-6-BOOTTIME: Time taken to reboot after reload =  105 seconds
*Oct 14 2016 20:48:17.951 EDT: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Oct 14 2016 20:48:18.024 EDT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 5818: Neighbor 10.20.30.1 (GigabitEthernet0/1) is up: new adjacency
*Oct 14 2016 20:48:18.072 EDT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 5818: Neighbor 10.255.255.1 (GigabitEthernet0/0) is up: new adjacencysionStamps
CNF files update complete (post init)
This is a privately owned system. Access to this device is
restricted to authorized persons only. Unauthorized access is
prohibited. Violators will be prosecuted.
******************************WARNING******************************
User Access Verification
Username: admin
Password:
BSMT2851#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
BSMT2851(config)#no b
*Oct 14 2016 20:50:08.046 EDT: %AAA-3-BADSERVERTYPEERROR: Cannot process accounting server type tacacs+ (UNKNOWN)
BSMT2851(config)#no boot system
BSMT2851(config)#dir   do dir
Directory of flash:/
    1  drw-           0  Aug 27 2016 08:42:18 -04:00  voip
   15  -rw-    65962916  Oct 14 2016 19:58:28 -04:00  c2800nm-advipservicesk9-mz.151-4.M9.bin
   16  -rw-       12507  Oct 13 2016 23:55:00 -04:00  config20161013_v15.1
   17  -rw-    57973000  Oct 14 2016 14:57:30 -04:00  c2800nm-spservicesk9-mz.151-3.T4.bin
   18  -rw-        9130  Aug 14 2016 01:22:04 -04:00  config20160814_1221
258646016 bytes total (122830848 bytes free)
BSMT2851(config)#do dir
BSMT2851(config)#boot system
BSMT2851(config)#boot system c2800nm-advipservicesk9-mz.151-4.M9.bin
BSMT2851(config)#end
BSMT2851#wr
[OK]
BSMT2851#
*Oct 14 2016 20:50:51.006 EDT: %SYS-5-CONFIG_I: Configured from console by admin on console
BSMT2851#reload
*Oct 14 2016 20:50:57.911 EDT: %SYS-5-RELOAD: Reload requested by admin on console. Reload Reason: Reload Command.
program load complete, entry point: 0x8000f000, size: 0x3ee81dc
Self decompressing the image : ##################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
  ID            MEMORY_REQ                 TYPE
                0X00262B0A Onboard VPN
TOTAL:          0X00BACEB2
Rounded IOMEM up to: 12Mb.
Using 1 percent iomem. [12Mb/1024Mb]
%C3600-3-SLOTS: Number of slots in chassis is undefined.
export@cisco.com.
%VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
%VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled Installed image archive
%SYS-6-CLOCKUPDATE: System clock has been updated from 00:52:52 UTC Sat Oct 15 2016 to 19:52:52 EST Fri Oct 14 2016, configured from console by console.
%SYS-6-CLOCKUPDATE: System clock has been updated from 19:52:52 EST Fri Oct 14 2016 to 20:52:52 EDT Fri Oct 14 2016, configured from console by console.
%LINK-3-UPDOWN: Interface ephone_dsp DN 2.1, changed state to uppropagate phone type from 'ephone-template 1' to 'ephone 1'
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/c2800nm-advipservicesk9-mz.151-4.M9.bin File read failed -- Timed out.
monitor: command "boot" aborted due to user interrupt
rommon 1 > dir flash:
Directory of flash:
3149    65962916  -rw-     c2800nm-advipservicesk9-mz.151-4.M9.bin
3655    0         drw-     voip
2      12507     -rw-     config20161013_v15.1
52134    57973000  -rw-     c2800nm-spservicesk9-mz.151-3.T4.bin
22     9130      -rw-     config20160814_1221
rommon 2 > unset o boot
unset: "boot" does not exist
rommon 3 > unser   t BOOT
rommon 4 > set
PS1=rommon ! >
GE_PORT=0
WARM_REBOOT=FALSE
BSI=0
RANDOM_NUM=938747256
RET_2_RTS=20:50:57 EDT Fri Oct 14 2016
RET_2_RCALTS=1476492661
RELOAD_TYPE=1
?=0
rommon 5 > set BOOT=c2800nm-advipservicesk9-mz.151-4.M9.bin
usage: set
rommon 6 > ?
alias               set and display aliases command
boot                boot up an external process
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
context             display the context of a loaded image
cookie              display contents of motherboard cookie PROM in hex
dev                 list the device table
dir                 list files in file system
dis                 disassemble instruction stream
dnld                serial download a program module
frame               print out a selected stack frame
help                monitor builtin command help
history             monitor command history
iomemset            set IO memory percent
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
rommon-pref         Select ROMMON
set                 display the monitor variables
showmon             display currently selected ROM monitor
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
tftpdnld            tftp image download
unalias             unset an alias
unset               unset a monitor variable
xmodem              x/ymodem image download
rommon 7 > set ?
usage: set
rommon 8 > set?
monitor: command "set?" not found
rommon 9 > boot
  ID            MEMORY_REQ                 TYPE
TOTAL:          0X00BACEB2
           cisco Systems, Inc.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(4)M9, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 12-Sep-14 10:45 by prod_rel_team
export@cisco.com.
Cisco 2851 (revision 1.0) with 1036288K/12288K bytes of memory.
*Oct 15 00:58:55.463: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 65535)) is not supported on this image.
*Oct 15 00:59:09.251: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
*Oct 15 00:59:09.255: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
*Oct 15 00:59:10.659: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Oct 15 00:59:10.659: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Oct 15 00:59:10.659: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Oct 15 00:59:10.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface Onboard VPN, changed state to up
*Oct 15 00:59:11.659: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, ch
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
anged state to up
*Oct 15 00:59:11.659: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Oct 14 2016 19:59:13.119 EST: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:59:13 UTC Sat Oct 15 2016 to 19:59:13 EST Fri Oct 14 2016, configured from console by console.
*Oct 14 2016 20:59:13.123 EDT: %SYS-6-CLOCKUPDATE: System clock has been updated from 19:59:13 EST Fri Oct 14 2016 to 20:59:13 EDT Fri Oct 14 2016, configured from console by console.
*Oct 14 2016 20:59:14.359 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback254, changed state to up
*Oct 14 2016 20:59:14.359 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback255, changed state to up
*Oct 14 2016 20:59:14.967 EDT: CEF-HWIDB: EDSP0 LES switching vector set to Null
*Oct 14 2016 20:59:14.967 EDT: CEF-HWIDB: EDSP0 LES switching vector set to CEF switching
*Oct 14 2016 20:59:14.971 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0 added.
*Oct 14 2016 20:59:15.567 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.1 added.
*Oct 14 2016 20:59:15.571 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.2 added.
*Oct 14 2016 20:59:15.571 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.3 added.
*Oct 14 2016 20:59:15.571 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.4 added.
*Oct 14 2016 20:59:15.571 EDT: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.5 added.
*Oct 14 2016 20:59:15.715 EDT: %LINK-3-UPDOWN: Interface ephone_dsp DN 1.1, changed state to up
*Oct 14 2016 20:59:15.715 EDT: %LINK-3-UPDOWN: Interface ephone_dsp DN 1.2, changed state to up
*Oct 14 2016 20:59:15.719 EDT: %LINK-3-UPDOWN: Interface ephone_dsp DN 2.1, changed state to up
*Oct 14 2016 20:59:16.159 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface EDSP0, changed state to up
*Oct 14 2016 20:59:16.255 EDT: %SYS-5-CONFIG_I: Configured from memory by console
*Oct 14 2016 20:59:16.631 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Oct 14 2016 20:59:16.631 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Oct 14 2016 20:59:19.795 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
*Oct 14 2016 20:59:20.931 EDT: %SYS-
  ID            MEMORY_REQ                 TYPE
Things started going wrong here.  During the bootup, the ROMmon refuses to acknowledge the existence of the NME card.
The error message is very misleading, however, there is a Cisco Bug which also states the same symptom:  CSCsj26408
According to this bug, disable Smart Init by issuing the command "memory-size iomem 25" might fix the issue.
If not, then I'm suspecting the router could be faulty.
Leo --
Thanks very much for the response.  After implementing your suggestion (with no improvement unfortunately) I removed the router and took out the non-ECC DIMM RAM card to see if that would allow the router to recognize the ES card when ECC was enabled (did not help).  While out of my rack I reseated the ES card for the 6th time (not an exaggeration), and the router recognized the card!  I then backtracked and removed all the fixes and it still worked, thus the final solution being the card was not seated correctly.
Sorry for the trouble.
Glad to see you've finally got it working.
the unambiguous problem was 2 years suffered ! the result is simply to clean the connector dad mom . where the switch is connected . medical alcohol and everything will work !!!
