2921 Vlan issues
Shaun McCloud
I am trying to set up a 2921 router to handle the vlans for the network.
I have added the vlans on the switch vlans 10-100 (counting by 10s), but i can not get the router to talk within the vlans.
everything that I read says to configer interface vlan but my router does not recognize the vlan command on the interface.
router show run:
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
vlan ifdescr detail
license udi pid CISCO2911/K9 sn FGL1617130G
redundancy
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description Internal Network
ip address 10.40.0.1 255.255.255.0
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 3
interface GigabitEthernet0/2
description Connection to T1 Router
ip address 10.40.250.2 255.255.255.0
duplex auto
speed auto
router rip
network 10.0.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.4.253.41
control-plane
end
glen.grant
  I believe the router will only use SVI's if the router has a mutli port switchcard installed which yours does not appear to have so your only option is to subinterface the router  and runn all traffic down a single interface to the router and set trunking on the switch side.
router side
int g0/1
desc vlan 10
int g0/1.10
encapsulation dot1q 10
ip address 192.168.10.1 255.255.255.0
int g0/1.20
desc vlan 20
encapsulation dot1q 20
ip add     192.168.20.1 255.255.255.0
and so on  for each subnet. Of course sunstitute the addresses shown with whatever you are using.  Switch side just setup as switchport mode trunk and encapsulation dot1q .
glen.grant
router side
int g0/1
desc vlan 10
int g0/1.10
int g0/1.20
desc vlan 20
With this configuration how does the dhcp server know what subnet belongs to which vlan?
Where is the DHCP server and how will DHCP requests get to it? The config that you show us does not have any DHCP scopes configured on the router and there are no helper addresses to forward requests to a DHCP server. The exact answer of how the DHCP server will know which subnet depends a bit on where the server is and how the request got to the server. But in general the answer is that the DHCP server will know the subnet from which the request came if it is directly connected or the request will have the gateway address if the request was forwarded and the server will use this information to identify the correct scope.
Rick
Rick
