2950 switch not prompting username and password
Cisco10956
I have setup my username and password on a Cisco 2950 switch for security. My computer is connected to the switch with a console cable.
When I restart my switch I get prompted for the enable password only.
Problem.
I do not get prompted for a username and password - Why ??- What am I doing wrong in my configuration.
These are the commands I have loaded on the switch.
enable secret Cisco1
username admin privilege 15 secret  Cisco
Try this command lines only:
username admin privilege 15 password Cisco
conf t
no aaa new-model
line vty 0 15 (or 0 4)
login local
line con 0
login local
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
11 Replies 11
Reza Sharifi
Try this command:
no username admin privilege 15 secret  Cisco
username admin privilege 15 password 7 Cisco
and test again.
Hi Reza the commands did not work
I received the following message after the last command line.
Invalid encrypted password
conf t
no aaa new-model
login local
line con 0
login local
Hope it is useful
Also this link could be useful:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_53_se/configuration/guide/2960scg/swauthen.html
Hi Julio - That was a very big help
doing a no aaa new-model, and adding the lines for vty and con.
It was simple but it worked. Thanks
God Bless and Have A Great Dat
It was pleasure  :-)
God Bless you and have a great day too
Thank you
Julio
I gave you 5 stars. - Just want to make sure,.
Dennis Mink
on your vty line 0 4
use "login local" command
please rate if useful.
Please remember to rate useful posts, by clicking on the stars below.
Dennis
Thanks but that did not work.
The command you sent is only good for using telnet from the network.
If a switch or router is connected by a console cable the first level of security I need to receive is a username and I am not getting that.
Hopes this helps
OK, yes, in that case stick the login local on the line console
Please rate if useful.
Mr Noone
If you are having the issue on the console interface only - use:
configure terminal
line con 0
login local
end
This should actually enable user authentication on console as well.
