2960-C and IP Routing
jmathias313
                   Will the C2960-C support static routes?  I have enabled sdm prefer lanbase-routing and reloaded.  The switch will not accept the command "ip routing" after a reload.  I did a show sdm prefer and the lanbase template is shown.
License Level: lanbase
License Type: Permanent
Switch Ports Model              SW Version            SW Image
*    1 10    WS-C2960C-8PC-L    12.2(55)EX3           C2960c405-UNIVERSALK9-M
Thanks...
James
6 Replies 6
Do you mean it returns with some error, or do you mean that it is not shown in the sh run?
I get the following after I enter "ip routing" or "ip route ..."
Invalid input detected at '^' marker.
check out this bug
CSCtu00997
Although you can apply the LAN base routing template to the switch, you cannot use the ip routing global configuration command.
There is no workaround
thanks
Yes
When I have try to enable ip routing but ISO not support.
I think we will need to change IOS,
if any one update which IOS update me.
Thanking you
Darshan Desai
singhaam007
Level 3
Level 3
looks like its the IOS
https://supportforums.cisco.com/thread/2136378
but its works on 12.2(55)SE
http://blog.alwaysthenetwork.com/tutorials/2960s-can-route/
please rate if this helps.
thanks
ehrenstef
You have to set "sdm prefer lanbase-routing" first.
After submitting this command the switch needs to reload abd then it will be able to create up to 8 vlan interfaces i think.
Now thr ip routing command should work too.
