Disabling ''igmp snooping'' in a VLAN (no interface VLAN) on Catalyst 6500
guillermo.ruiz
Can please some help?
On 4948 or 3560 I can disable igmp snooping in a specific VLAN:
sw4948(config)#no ip igmp snooping vlan ?
  <1-1001>     Vlan number
  <1006-4094>  Vlan number
sw4948(config)#no ip igmp snooping vlan 10 ?
  explicit-tracking           Enable IGMP explicit host tracking
  immediate-leave             Enable IGMPv2 immediate leave processing
  last-member-query-interval  Last member query interval
  mrouter                     Configure an L2 port as a multicast router port
  static                      Configure an L2 port as a member of a group
  <cr>
BUT, in 6509-E this command is not enabled:
sw6509(config-if)#no ip igmp snooping ?
  access-group  IGMP group access group
  limit         IGMP limit
I have just found on my 6509 that I can disable igmp snooping in a SVI interface (Interface VLAN)
sw6509(config)#int vlan 20
  fast-leave                  Enable IGMP fast leave processing
  last-member-query-interval  Configure IGMP leave query timeout
  limit                       IGMP limit
  minimum-version             Minimum IGMP version
  querier                     Enable IGMP querier processing
  report-suppression          Force a report suppression
  ssm-safe-reporting          Enable SSM Safe Reporting
  <cr>
My current 6509-E IOS version is:
System image file is "sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXH8b.bin"
Do I need to upgrade my IOS version?... or how can I disable ''igmp snooping'' per specific VLAN (no Interface VLAN)?
Any help would be apreciated !
guruiz
7 Replies 7
guillermo.ruiz
I made a mistake on the copy and paste. Correct info must be as follows:
sw6509(config)#no ip igmp snooping ?
cgmp                 configure CGMP option
l2-entry-limit       limit on the l2 entry that can be installed by IGMP snooping
limit                 Configure IGMP Snooping limits
source-only-learning source-only gce entries
Any ideas?
guruiz
It is not your IOS. The command is only available under the SVI and not just for layer-2 vlan or can be enabled globally.
Here is an example from the SXI release:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/snooigmp.html#wp1121158
Reza,
Thank you much for your answer.
Just a pair of questions, if you could please give your comments:
So, to disable igmp snooping in some VLANs in the 6509, do I need to disable it globally?
Would it be the only way?
How could "no ip igmp snooping" applied globally impact my 6509 switch?
Kind regards,
guruiz
Hi Guruiz,
That appears to be the only way. If you have an SVI for the vlan you want to run Multicast in, then simply enable PIM and not worry about IGMP snooping.  I think, the reason you don't see this command under the layer-2 vlan is because most of the time the 6500 is used as layer-2/layer-3 and not just layer-2.
It will impact only the vlans that are running Multicast.  In general, ip IGMP snooping is used when you have a flat vlan and no SVI.  If you have multiple vlans and are running Multicast between them, then you can just enable PIM.
Reza,
Fantastic information.
I´m very grateful.
Best regards,
guruiz
Hi Raza,
Just to clarify, What is the impact If I disable IGMP Snooping disabled globally and enable on specific SVI? e.g
Config# no ip igmp snooping
Config# inter vlan 1
Config-if)#ip igmp snooping
And What is the impact If I disable IGMP Snooping Querier globally and enable on specfic SVI?
Config# no ip igmp snooping querier
Config-if)#ip igmp snooping querier
Will IGMP snooping & Querier work for specific VLAN only If disabled globally?
Anser
You can disable igmp in one vlan with the next command:
config# vlan configuration "#vlan"
            no ip igmp snooping
