2960 Switch models....
Richard Tapley
Level 3
Level 3
I wonder if I can get some advice on switch options.
I am looking for a Cisco 2960 8 port with 2 dual purpose uplinks ( SFP and copper 1GB ).
I have seen in some places the 2960C-8TC-L has the 2 uplinks and then in another it doesn't. All Cisco pages.
I then found the WS-C2960CX-8TC-L which says it does.
Is the 2960CX the replacement model or a different model?
Am I being stupid or is there a place where I can get difinitive info on the 2960C-8TC-L so that I know the specific part number of the one with 1 uplink and the one with 2 so I can order the right one and not get strung up by work!!?
Thanks for any assistance.
2 Accepted Solutions
Reza Sharifi
Hi Richard,
Have a look at this comparison sheet (at the bottom of the page) for the 2 different 2960 switches.
The difference is POE vs none-POE.
http://www.cisco.com/c/en/us/products/switches/catalyst-3560-cx-series-switches/models-comparison.html
Hi Richard,
WS-C2960C-8TC-L definitely has two uplinks as in 2 X copper or 2X SFP,I've got few of these around.it is old WS-C2960-8TC-L (note there's no C after 2960)part number which used to come with 1 uplink port which is end of sale already
now I don't have any CX part numbered devices to check,it seems 2960CX is the replacement for 2960C and there is  bit of a mention here under upgrade and ordering information, however I can't find anything directly related to the 2960C-8TC-L part number
"The 3560-CX and 2960-CX Series include an equivalent or better replacement for each Cisco Catalyst 3560-C and 2960-C Gigabit Ethernet model."
Here is the link for just 2960C series and previous link has the part number for the CX ones
Cheers,
Prabath
***Please rate all the useful posts***
-Prabath
Reza Sharifi
Hi Richard,
Hi Richard,
Cheers,
Prabath
-Prabath
Richard Tapley
Level 3
Level 3
Hi Prabath and Reza,
Thank you for coming back so quickly.
That is exactly the answers I was looking for and can only assume in my searches  I missed the placement of the C.
Huge thank you I can now order the correct kit.
