2960-X - Boot Fail after Firmware upgrade
kalweit01
I was upgrading the firmware of one of our 2960-X Switches to c2960x-universalk9-tar.152-2.E3. When the firmware was updated the switch rebooted and was coming up with "BOOT FAIL".
I am not able to get to ROMmon. It has no reaction if I press the Mode button at start or trying to send a break in Terminal, also a CTRL+C, CTRL+Break or any other key combinations are not helping.
Any suggestions?
7 Replies 7
Mark Malone
I would repost that in this link below as there's a cisco 2960x expert answering questions until Friday on these platforms, you should also provide the terminal output as it boots up an the steps you took to deploy it , the more information the quicker you will get a solution
https://supportforums.cisco.com/discussion/12982571/ask-expert-catalyst-2960-x-and-2960-xr-switches-overview-configuration-and
Posted it there too. Thx for the hint.
jackson.ku
Level 3
Level 3
I have got the same issue. Do you find the method to resolve it?
Best Regards,
Jackson Ku
I have got the same issue too.
can anyone help us!!!
Abrar_Ali
I am facing the same issue. If you found a resolution, please share as i need it on urgent basis.
abrar.exalted@gmail.com is my e-mail.
Thanks and regards.
saloaun18
hi, did u resolve this issue?
By changing the device lol
