2960 XL and no L2protocol command
evan.chadwick1
Hi All,
I'm hoping to configure a port as a l2protocol-tunnel. I don't see the command available when using question mark on a switchport mode access port.
Can a 2960 XL running 15.2 utilize l2protocol tunnels?
WS-C2960X-24PS-L
It appears this model can't perform L2p. High probability that the XR can.
if  you upgrade the X to 15.2.6 you can create q in q tunnel (not specific with vtp/stp/cdp)
Closing..
Leo Laohoo
2960 or 2900XL-EN?
WS-C2960X-24PS-L
Closing..
r.heitmann
this is an old thread, I know... Just to fix the accepted solution:
#show inv
NAME: "1", DESCR: "WS-C2960X-48FPD-L"
no XR  - can run dot1q-tunnel fine:
interface GigabitEthernet1/0/13
 switchport access vlan 4094
 switchport mode dot1q-tunnel
 spanning-tree portfast edge
but no "l2protocol-tunnel {cdp|lldp|...}"
(config-if)# l2?
% Unrecognized command
so - only software-release dependent, not about X or XR.
