2960-XR no PoE on particular port for IP Camera
Todd Willoughby
I am having issues with one of my 2960 XR switches not giving link or poe power to a known working IP Camera (Axis M3005). I actually have two ports (gi1/0/30 and 31) right next to each other that are not giving me no link light or poe power for my IP camera. I have set each side the camera and the switch to the required 100mb Full duplex still nothing. I can plug the Camera into another 2960XR (same model same specs) switch and it comes right on with a link light. I have posted the environment and inline power results below. CDP is also disabled on the port as per IP Axis instructions. Inline power is also set to auto. I have also plugged this camera into another 3560X switch and it working fine as well there.  This is the master switch in a stack of 3 2960XRs as well. Im also getting a odd error in the log that says "Apr 27 11:14:50.218: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding." Although the sh env command tells a different story.
2960XR-Stack1#sh power inline
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1           740.0      160.0       580.0
2           740.0      177.2       562.8
3           740.0       72.0       668.0
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi1/0/1   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/2   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/3   auto   on         7.0     Ieee PD             2     30.0
Gi1/0/4   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/5   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/6   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/7   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/8   auto   on         15.4    Ieee PD             3     30.0
Gi1/0/9   auto   on         7.0     Ieee PD             2     30.0
Gi1/0/10  auto   on         7.0     Ieee PD             2     30.0
Gi1/0/11  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/12  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/13  auto   on         12.0    IP Phone 7975       3     30.0
Gi1/0/14  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/15  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/16  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/17  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/18  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/19  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/20  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/21  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/22  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/23  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/24  auto   on         4.0     Ieee PD             1     30.0
Gi1/0/25  auto   on         15.4    MR32                4     30.0
Gi1/0/26  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/27  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/28  auto   on         15.4    Ieee PD             3     30.0
Gi1/0/29  auto   on         4.0     Ieee PD             1     30.0
Gi1/0/30  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/31  static off        30.0    n/a                 n/a   30.0
Gi1/0/32  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/33  auto   on         15.4    MR32                4     30.0
Gi1/0/34  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/35  auto   on         12.0    IP Phone 7975       3     30.0
Gi1/0/36  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/37  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/38  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/39  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/40  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/41  auto   on         15.4    Ieee PD             0     30.0
Gi1/0/42  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/43  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/44  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/45  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/46  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/47  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/48  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/1   auto   on         15.4    Ieee PD             0     30.0
Gi2/0/2   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/3   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/4   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/5   auto   on         15.4    Ieee PD             3     30.0
Gi2/0/6   auto   on         7.0     Ieee PD             2     30.0
Gi2/0/7   auto   on         4.0     Ieee PD             1     30.0
Gi2/0/8   auto   off        0.0     n/a                 n/a   30.0
2960XR-Stack1#sh env all
FAN PS-1 is OK
FAN PS-2 is NOT PRESENT
SYSTEM TEMPERATURE is OK
System Temperature Value: 36 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 67 Degree Celsius
Red Threshold    : 75 Degree Celsius
POWER SUPPLY 1A TEMPERATURE: OK
POWER SUPPLY 1B TEMPERATURE: Not Present
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  PWR-C2-1025WAC      DCB1737C0KY OK              Good     Good     250/775
1B  Not Present
2A  PWR-C2-1025WAC      DCB1737C0BV OK              Good     Good     250/775
2B  Not Present
3A  PWR-C2-1025WAC      DCB1737C0BF OK              Good     Good     250/775
3B  Not Present
2960XR-Stack1#sh int gi1/0/31
GigabitEthernet1/0/31 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 64e9.50e9.0b9f (bia 64e9.50e9.0b9f)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 01:38:22, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     108 packets input, 10678 bytes, 0 no buffer
     Received 108 broadcasts (79 multicasts)
     0 watchdog, 79 multicast, 0 pause input
     33 packets output, 2504 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
2960XR-Stack1#sh ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2)EX4,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 14-Nov-13 11:33 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.0(2r)EX1, RELEASE SOFTWA
RE (fc1)
2960XR-Stack1 uptime is 1 year, 15 weeks, 1 day, 15 hours, 3 minutes
System restarted at 15:19:53 UTC Fri Jan 10 2014
System image file is "flash:/c2960x-universalk9-mz.150-2.EX4/c2960x-universalk9-
mz.150-2.EX4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960XR-48FPD-I (APM86XXX) processor (revision A0) with 524288K bytes o
f memory.
Processor board ID FDO1742B01J
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
150 Gigabit Ethernet interfaces
6 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 64:E9:50:E9:0B:80
Motherboard assembly number     : 73-15626-02
Power supply part number        : 341-0533-01
Motherboard serial number       :
Power supply serial number      :
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C2960XR-48FPD-I
Daughterboard assembly number   :
Daughterboard serial number     :
System serial number            :
Top Assembly Part Number        : 68-5044-01
Top Assembly Revision Number    : A0
Version ID                      : V01
CLEI Code Number                : CMMKJ10ARA
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x06
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960XR-48FPD-I 15.0(2)EX4            C2960X-UNIVERSALK9-M
     2 52    WS-C2960XR-48FPD-I 15.0(2)EX4            C2960X-UNIVERSALK9-M
     3 52    WS-C2960XR-48FPD-I 15.0(2)EX4            C2960X-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 1 year, 15 weeks, 1 day, 15 hours, 3 minutes
Base ethernet MAC Address       : 64:E9:50:E8:FF:80
Daughterboard assembly number   : 73-14200-03
Top assembly part number        : 68-5044-01
Top assembly revision number    : A0
Version ID                      : V01
Switch 03
Base ethernet MAC Address       : 34:DB:FD:1F:94:80
Model revision number           : V01
Version ID                      : V01
Configuration register is 0xF
Marvin Rhoads
Have you used a cable tester on the drop to make sure all the necessary pairs have end-end continuity?
Marvin,
Correct we have toned out both ends of the cables all test fine. I even tried plugging the device directly into the switch. Still no link or power
