2960G switch port not responding
manoj.kumar0074
Hi All,
I have 2960-G switch , last few days i am facing problem with it.Some ports are not responding .LED blinks but no packets are send or receive.
I tried a lot by restarting it and even I had restore default the switch but no luck.Pls find attached text file for config details............
10 Replies 10
Anton Noskov
Hi.
It`s  a  random ports or one group ports?
Did you had a problem   with power sapply ?
rocco.scholz
what is the status of those ports - notconnected,errdisabled? Please post a "show interface status" output and also an "show interface  ge 0/x" from affected port.
Dear Rocco.scholz,
please find below mention output ....
show interfaces gigabitEthernet 0/12
GigabitEthernet0/12 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 0023.abe2.440c (bia 0023.abe2.440c)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
CH-ADMIN_CABIN-ASC-01#
CH-ADMIN_CABIN-ASC-01#show interfaces gigabitEthernet 0/13
GigabitEthernet0/13 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 0023.abe2.440d (bia 0023.abe2.440d)
CH-ADMIN_CABIN-ASC-01#show interfaces status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/1                        connected    244        a-full   a-10 10/100/1000BaseTX
Gi0/2                        connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/3                        connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/4                        notconnect   244          auto   auto 10/100/1000BaseTX        seTX
Gi0/5                        connected    244        a-full a-1000 10/100/1000BaseTX        seTX
Gi0/6                        connected    244        a-full   a-10 10/100/1000BaseTX        seTX
Gi0/7                        connected    244        a-full a-1000 10/100/1000BaseTX        seTX
Gi0/8                        connected    244        a-full a-1000 10/100/1000BaseTX        seTX
Gi0/9                        notconnect   244          full   auto 10/100/1000BaseTX        seTX
Gi0/10                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/11                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/12                       notconnect   244          auto   auto 10/100/1000BaseTX        seTX
Gi0/13                       notconnect   244          auto   auto 10/100/1000BaseTX        seTX
Gi0/14                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/15                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/16                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/17                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/18                       notconnect   244          auto   auto 10/100/1000BaseTX        seTX
Gi0/19                       notconnect   244          auto   auto 10/100/1000BaseTX        seTX
Gi0/20                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/21                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/22                       connected    244        a-full   a-10 10/100/1000BaseTX        seTX
Gi0/23                       connected    244        a-full  a-100 10/100/1000BaseTX        seTX
Gi0/24                       connected    trunk      a-full  a-100 10/100/1000BaseTX        seTX
Are these ports coming from a client with NIC Teaming turned on?
Hi, as leolaohoo wrote please tell us what kind of device is connected to these ports. From your show int status I can see that all counters are zero so I think these ports were never up. Have you tried to connect directly with a notebook to one of these ports?
hi rocco.scholz,
Our end users were connected through these ports but due the problem i had remove them and restart the switch.
Now the problem is that the ports were randomly not responding and within 7 days total 5 nos ports were useless.
Even I had connected my laptop on these ports but it shows not connected.
have you already tried a online diagnostic test?
Leo Laohoo
Post the config for the ports.
Maybe BPDU Guard is enabled or port security or something could be sending the ports into error-disable.
bojan15584
Try   show post  command
If there is something wrong with ports there should be some errors...
Hi Leo,
they would be  in errdisabled state but here they are in notconnect state.
But giving us a show run interface output  would maybe tell us a little bit more.
Regards.
