2960L SVI issue
AdamW01248
I have a 24port 2960-L (running the latest IOS) which being passive cooled fits my requirement well.
I have configured it with a number of VLANs with a SVI on each and enabled routing.
Seemingly at random an SVI stops responding. Unfortunately I was in a hurry to get things working so power cycled the switch which resolved the issue. I'm hopeful next time it occurs (its already happened a number of times) I can get a laptop and console cable to see what's happening. Other than that its working perfectly.
Has anyone experienced a similar issue with the 2960-L series? any hints on where to look for issues?
21 Replies 21
Is there anything else I shoulld test before i do shutdown/no shutdown and run the commands again?
this is an old thread, are you experiencing the exact same problem ? Post the output of:
sh ver
Georg, yes I think that it is the same problem, except that we dont have routing enabled. SVI randomly stops responding, and we have to restart the switch or do a shutdown/no shutdown on the vlan interface to get it working again.
It dont happen that often, we have about a hundred C2960L in our network, and this has happend 10-15 times in a year.
Different switches, some once , a couple of them two times. Different firmware 15.2(7)E0 - E3
Drottningatan_22_C2960_193.65#show ver
Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(7)E2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sat 14-Mar-20 15:38 by prod_rel_team
ROM: Bootstrap program is C2960L boot loader
BOOTLDR: C2960L Boot Loader (C2960L-HBOOT-M) Version 15.2(5r)E3, RELEASE SOFTWARE (fc2)
Drottningatan_22_C2960_193.65 uptime is 29 weeks, 6 days, 3 hours, 15 minutes
System restarted at 10:10:43 UTC Fri Jul 31 2020
System image file is "flash:c2960l-universalk9-mz.152-7.E2/c2960l-universalk9-mz.152-7.E2.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960L-24PS-LL (Marvell PJ4B (584) v7 (Rev 2)) processor (revision G0) with 524288K bytes of memory.
Processor board ID FCW2313A1AL
Last reset from Reload
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : AC:F5:E6:05:92:00
Motherboard assembly number : U58O342T03
Power supply part number : 341-100560-01
Motherboard serial number : FOC23117Z49
Power supply serial number : LIT23072Q4W
Model revision number : G0
Motherboard revision number : 23
Model number : WS-C2960L-24PS-LL
System serial number : FCW2313A1AL
Top Assembly Part Number : 74-105856-01
Top Assembly Revision Number : H0
Version ID : V01
CLEI Code Number : CMMWK00ARA
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960L-24PS-LL 15.2(7)E2 C2960L-UNIVERSALK9-M
Configuration register is 0xF
You asked "Is there anything else I should test before i do shutdown/no shutdown and run the commands again?" I would say run the commands, verify that the addresses in the arp table, attempt to traceroute to each of the IP addresses in the arp table, check for any log messages, then shut/no shut, and run the commands again. I would hope that we might find something different in the before and after outputs.
Rick
Before I do shutdown/no shutdown on interface Vlan 1:
Drottningatan_22_C2960_193.65#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.193.1 0 4431.92f8.1faa ARPA Vlan1
Internet 192.168.193.65 - acf5.e605.9240 ARPA Vlan1
Drottningatan_22_C2960_193.65#show ip route
Default gateway is 192.168.193.1
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
Drottningatan_22_C2960_193.65#show ip inte brief
Vlan1 192.168.193.65 YES NVRAM up up
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset down down
GigabitEthernet0/3 unassigned YES unset down down
GigabitEthernet0/4 unassigned YES unset up up
GigabitEthernet0/5 unassigned YES unset up up
GigabitEthernet0/6 unassigned YES unset down down
GigabitEthernet0/7 unassigned YES unset down down
GigabitEthernet0/8 unassigned YES unset down down
GigabitEthernet0/9 unassigned YES unset up up
GigabitEthernet0/10 unassigned YES unset down down
GigabitEthernet0/11 unassigned YES unset up up
GigabitEthernet0/12 unassigned YES unset down down
GigabitEthernet0/13 unassigned YES unset up up
GigabitEthernet0/14 unassigned YES unset down down
GigabitEthernet0/15 unassigned YES unset up up
GigabitEthernet0/16 unassigned YES unset up up
GigabitEthernet0/17 unassigned YES unset down down
GigabitEthernet0/18 unassigned YES unset down down
GigabitEthernet0/19 unassigned YES unset down down
GigabitEthernet0/20 unassigned YES unset up up
GigabitEthernet0/21 unassigned YES unset up up
GigabitEthernet0/22 unassigned YES unset up up
GigabitEthernet0/23 unassigned YES unset up up
GigabitEthernet0/24 unassigned YES unset up up
GigabitEthernet0/25 unassigned YES unset down down
GigabitEthernet0/26 unassigned YES unset down down
GigabitEthernet0/27 unassigned YES unset down down
GigabitEthernet0/28 unassigned YES unset down down
Bluetooth0 unassigned YES unset administratively down down
Drottningatan_22_C2960_193.65#show inte status
Port Name Status Vlan Duplex Speed Type
Gi0/1 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/2 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/3 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/4 connected 153 a-full a-1000 10/100/1000BaseTX
Gi0/5 connected 153 a-full a-100 10/100/1000BaseTX
Gi0/6 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/7 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/8 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/9 connected 153 a-full a-1000 10/100/1000BaseTX
Gi0/10 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/11 connected 153 a-full a-1000 10/100/1000BaseTX
Gi0/12 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/13 connected 153 a-full a-1000 10/100/1000BaseTX
Gi0/14 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/15 connected 153 a-full a-1000 10/100/1000BaseTX
Gi0/16 connected 153 a-full a-1000 10/100/1000BaseTX
Gi0/17 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/18 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/19 notconnect 153 auto auto 10/100/1000BaseTX
Gi0/20 connected 163 a-half a-100 10/100/1000BaseTX
Gi0/21 connected 163 a-full a-100 10/100/1000BaseTX
Gi0/22 connected 163 a-full a-100 10/100/1000BaseTX
Gi0/23 connected 2206 a-full a-100 10/100/1000BaseTX
Gi0/24 Radiolink Linkarve connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/25 notconnect 1 auto auto Not Present
Gi0/26 notconnect 1 auto auto Not Present
Gi0/27 notconnect 1 auto auto Not Present
Gi0/28 notconnect 1 auto auto Not Present
Drottningatan_22_C2960_193.65#show inte trunk
Port Mode Encapsulation Status Native vlan
Gi0/24 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/24 1-4094
Port Vlans allowed and active in management domain
Gi0/24 1,153,163,2206
Port Vlans in spanning tree forwarding state and not pruned
Drottningatan_22_C2960_193.65#traceroute 192.168.193.1
Tracing the route to 192.168.193.1
VRF info: (vrf in name/id, vrf out name/id)
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Drottningatan_22_C2960_193.65#ping 192.168.193.1
Sending 5, 100-byte ICMP Echos to 192.168.193.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
After I did shutdown/no shutdown on interface Vlan 1 (the switch is now reachable):
.Feb 26 05:58:11.265: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
.Feb 26 05:58:11.266: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
.Feb 26 05:58:16.832: %SYS-5-CONFIG_I: Configured from console by console
.Feb 26 05:58:52.705: %LINK-3-UPDOWN: Interface Vlan1, changed state to up
.Feb 26 05:58:52.706: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
.Feb 26 05:58:57.968: %SYS-5-CONFIG_I: Configured from console by console
Gi0/24 1-4094
Drottningatan_22_C2960_193.65#tracert 192.168.193.1
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/3/4 ms
I think it has to do something with spanning tree. Yesterday we had problem with a wireless bridge flapping, some nearby switches saw a mac adress on both uplink and downlink (though it is not physically possible), after that three C2960L had lost connection to management IP (SVI Vlan 1).
When we log in to them via console, there is nothing about it in the log and nothing abnormal about spanning tree.
