2960S Flexstack cabling depth
robspain2004
I wan to install a 2960S stack in an ADC patch frame that has a wall directly behind it.
I will have about 100mm (4 inches) clearance between the rear of the 2960S and the wall.
Is that sufficient clearance to install/remove the flexstack cables without damaging the cables? (i.e. too tight a turn radius)
Rob Spain
UK
Reza Sharifi
Rob,
It is going to be very tight, because the tip of the flex cable is about 1.5 to 2 inches long. You also need room for you hand to install/remove the cables without damaging them.  Also, with that much clearance, you can not remove the FlexStack module without undoing the switch from the rack.
Reza
Thanks Reza. Appreciated
