2960S PoE and Phone issues
venturas05
I have recently replaced some Catalyst 3550's with Catalyst 2960s PoE 48 port switches. Since the replacement I have had some issues with phones that will not have a dial tone. They are powered and the network config shows the correct configuration. They have the correct addresses for call manager and the router handling inter-campus calling. We tag the voice vlan separate from data and we use auto qos voip on the switches. Any assistance will be appreciated.
I have eliminated the phones by replacing one with a known working phone and taking another to another location. The known working phone would not work on the campus with the issue and the phone that would not work on that campus works on another campus.
where is interface vlan 3(SVI)? you also need to enable CDP for the IP Phone to work
Alessio
5 Replies 5
Leo Laohoo
Post the config of the new 2960S.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.09.25 10:17:55 =~=~=~=~=~=~=~=~=~=~=~=
TFB-MDF-2960s-1#  show run
Building configuration...
Current configuration : 18358 bytes
! No configuration change since last restart
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname TFB-MDF-2960s-1
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default group radius local
aaa session-id common
clock timezone UTC -6
clock summer-time UTC recurring
switch 1 provision ws-c2960s-48fps-l
mls qos map policed-dscp  0 10 18 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
spanning-tree mode pvst
auto qos srnd4
vlan internal allocation policy ascending
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
  set dscp ef
  police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
  set dscp cs3
  police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
  set dscp default
  police 10000000 8000 exceed-action policed-dscp-transmit
interface FastEthernet0
no ip address
shutdown
******* Interface Gi1/0/1-24 are configured as shown below ************
interface GigabitEthernet1/0/1
switchport access vlan 3
switchport trunk native vlan 3
switchport trunk allowed vlan 3,103
switchport mode trunk
switchport voice vlan 103
srr-queue bandwidth share 1 30 35 5
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
******* Interface Gi1/0/25-36 are configured as shown below for PoE Cameras ************
interface GigabitEthernet1/0/25
switchport access vlan 201
switchport mode access
******* Interface Gi1/0/37-48 are configured as shown below for PoE clocks ************
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/49
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
interface GigabitEthernet1/0/50
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
interface GigabitEthernet1/0/51
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
interface GigabitEthernet1/0/52
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
interface Vlan1
ip address x.x.x.x x.x.x.x
ip default-gateway x.x.x.x
ip http server
ip http authentication local
ip http secure-server
ip access-list extended AUTOQOS-ACL-DEFAULT
permit ip any any
ip sla enable reaction-alerts
Alessio
The vlan interfaces are configured on our core switch and updated to the switches via VTP. From my understanding I do not need to configure CDP on the switch it is already configured by default. Also, should have mentioned this earlier but we do have other models of phones on these switches and they are working correctly. We have 4 7912's that are not working correctly. If we reset them they will work for a few hours before they lose dial tone again.
This issue was resolved when we discovered that after turning on WoL older HP desktops started sending out fragmented packets in the millions causing all kinds of problems within the network. Since the driver update the issue has not repeated.
