Cisco 3750 (WS-C3750-48P ) two port showing err-disable and amber
Subhasis Dutta
In our company 3nos Cisco 3750 (WS-C3750-48P) access switch in stake mode. All port are assigned with voice and data Vlan also Avaya IP connected with this switches. From last few days tow port 2/0/7 and 2/0/8 is showing amber and status is showing err-disable. At Avaya end it is showing a message “ETHERNET WAITING” in phone dispaly. I try to connect laptop directly with these ports but it is showing "Cross Connectivity". Pls suggest me how to resolve this issue. Below is the port status and config:
interface FastEthernet2/0/6
switchport access vlan XXX
switchport mode access
switchport voice vlan YYY
switchport port-security maximum 2
switchport port-security maximum 1 vlan access
switchport port-security maximum 1 vlan voice
speed 100
duplex full
priority-queue out
udld port aggressive
mls qos trust dscp
no mdix auto
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
spanning-tree guard root
interface FastEthernet2/0/7
speed 100
duplex full
priority-queue out
mls qos trust dscp
no mdix auto
no cdp enable
interface FastEthernet2/0/8
speed 100
duplex full
priority-queue out
mls qos trust dscp
no mdix auto
no cdp enable
interface FastEthernet2/0/9
speed 100
duplex full
priority-queue out
mls qos trust dscp
no mdix auto
no cdp enable
Pls find the below mention port status:
FastEthernet2/0/7 is down, line protocol is down (err-disabled)
  Hardware is Fast Ethernet, address is 9caf.ca9e.9809 (bia 9caf.ca9e.9809)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 4w1d, output never, output hang never
  Last clearing of "show interface" counters 4d00h
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     400825 packets output, 52869912 bytes, 0 underruns
FastEthernet2/0/8 is down, line protocol is down (err-disabled)
  Hardware is Fast Ethernet, address is 9caf.ca9e.980a (bia 9caf.ca9e.980a)
  Last input 3w5d, output never, output hang never
  Last clearing of "show interface" counters 1w2d
     3207163 packets output, 421479136 bytes, 0 underruns
Hello
i am assuming tou dont have error recover enabled? so have you tried shutting these ports down and enable them again to reset the error disable and see if your port error disable yet again
if they do then i would check what is attached to these port to make sure that it is indeed a ip phone or some other device
causing this error
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Leo Laohoo
Seriously, you got "udld aggressive" on a copper port????
Take that line off!  It is highly recommended to use "udld aggressive" ONLY on fibre optic ports.
Post the output to the command "sh interface status err".
vaibhav.singh
Have you tried reverting the ports to default and then just having these under it:
default interface FastEthernetX/0/X
shut
no shut
Also, its a good idea to have mdix enabled and as stated above - there is no need for udld on copper ports.
Daniel McDavid
I bet both of those ports are plugged in to the back of the phone. I see this all the time.
