2960X constant reboot
Wil78
we have a 2960 that does not start the operating system, I have tried with several versions of ios and it has been impossible, after trying to FFFF up . bin from a USB stick with different versions and the result has been the same, also proceed to format the flash, copy the image from a USB or XMODEM but still not finished charging the operating system.
what seems strange to me is that the flash appears a crash_info.
switch: copy usbflash0:c2960x-universalk9-mz.152-7.E3.bin flash:c2960x-universalk9-mz.152-7.E3.bin
File "usbflash0:c2960x-universalk9-mz.152-7.E3.bin" successfully copied to "flash:c2960x-universalk9-mz.152-7.E3.bin"
switch: DIR
Unknown cmd: DURIR
switch: dir
List of filesystems currently registered:
bs[1]: (read-only)
flash[9]: (read-write)
xmodem[10]: (read-only)
null[11]: (read-write)
usbflash0[13]: (read-write)
tftp[14]: (read-only)
switch: dir flash:
Directory of flash:/
2 drwx 512 <date> crashinfo_ext
6 -rwx 26714112 <date> c2960x-universalk9-mz.152-7.E3.bin
92198K bytes available (27124K bytes used)
switch: delete flash:crashinfo_ext
Are you sure you want to delete "flash:crashinfo_ext" (y/n)?y
File "flash:crashinfo_ext" not deleted -- is a directory
switch: delete ?
Are you sure you want to delete "?" (y/n)?
File "?" not deleted
switch:
switch:
switch:
switch:
switch:
switch:
switch:
switch: dir flash:
switch: delete /recursive flash:crashinfo_ext
Are you sure you want to delete "/recursive" (y/n)?y
File "/recursive" not deleted -- no such device
switch:
switch:
switch:
switch:
deletdeleteursive flash:crashinfo_ext
Unknown cmd:
switch: dir flash:
switch: help
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
ping -- Send ICMP ECHO_REQUEST packets to a network host
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
sleep -- Pause (sleep) for a specified number of seconds
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
-- MORE --
version -- Display boot loader version
switch: set boot flash:/c2960x-universalk9-mz.152-7.E3.bin
switch: reset
Are you sure you want to reset the system (y/n)?y
System resetting...
CPU rev: B
Image passed digital signature verification
Board rev: 24
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 00:41:d2:7a:fd:80
The password-recovery mechanism is enabled.
APM USBUSB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 833536
mifs[5]: Bytes available : 972800
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 2 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1213440
mifs[6]: Bytes available : 2657280
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 4 files, 2 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 27774976
mifs[9]: Bytes available : 94410752
mifs[9]: mifs fsck took 30 seconds.
...done Initializing Flash.
Loading "flash:/c2960x-universalk9-mz.152-2.E4/c2960x-universalk9-mz.152-2.E4.bin"...
Error loading "flash:/c2960x-universalk9-mz.152-2.E4/c2960x-universalk9-mz.152-2.E4.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960x-universalk9-mz.152-7.E3.bin"...Verifying image flash:/c2960x-universalk9-mz.152-7.E3.bin........................................................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:/c2960x-universalk9-mz.152-7.E3.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(7)E3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sun 06-Sep-20 12:56 by prod_rel_team
Initializing flashfs...
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 833536
mifs[7]: Bytes available : 972800
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1213440
mifs[8]: Bytes available : 2657280
mifs[8]: mifs fsck took 1 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 4 files, 2 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 27774976
mifs[11]: Bytes available : 94410752
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
extracting front_end/front_end_ucode_info (43 bytes)
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 23
POST: PortASIC Port Loopback Tests : End, Status Failed
Error: ASIC/PHY POST failed. Cannot continue.
%Software-forced reload
18:44:38 UTC Sat Jan 1 2000: Unexpected exception to CPUvector 2000, PC = 3B6C968
-Traceback= 0x3B6C968z 0x35A0F98z 0x3626EDCz 0x2D1E6F4z 0x2D1E8D0z 0x2D1EA48z 0x7F8910z 0x7F8B80z 0x3B6DF54z 0x3B69C44z
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_4
=== Flushing messages (18:44:42 UTC Sat Jan 1 2000) ===
Buffered messages:
Queued messages:
Jan 1 18:44:42.962: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:19.825: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.153: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Jan 1 18:44:03.120: in Switch 0. Cannot read pid from Flexstack module
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x033D4CFC SRR1 = 0x00029200 SRR2 = 0x03B6C968 SRR3 = 0x00029200
ESR = 0x00000000 DEAR = 0x6FC5E8EF TSR = 0x84000000 DBSR = 0x01000000
CPU Register Context:
Vector = 0x00002000 PC = 0x03B6C968 MSR = 0x00029200 CR = 0x28000082
LR = 0x03B6C900 CTR = 0x007CE78C XER = 0x40000022
R0 = 0x03B6C900 R1 = 0x088E1B48 R2 = 0x00000000 R3 = 0x050D4620
R4 = 0x00000000 R5 = 0x00000000 R6 = 0x00000000 R7 = 0x00000025
R8 = 0x00000000 R9 = 0x05940000 R10 = 0x05950000 R11 = 0x00000000
R12 = 0x28000088 R13 = 0x1F183AF4 R14 = 0x007F8B24 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000001 R27 = 0x00000002
R28 = 0x0588BB8C R29 = 0x05950000 R30 = 0x088E1B88 R31 = 0x00000000
Stack trace:
PC = 0x03B6C968, SP = 0x088E1B48
Frame 00: SP = 0x088E1B58 PC = 0x03B6C900
Frame 01: SP = 0x088E1B80 PC = 0x035A0F98
Frame 02: SP = 0x088E1BE0 PC = 0x03626EDC
Frame 03: SP = 0x088E1BF0 PC = 0x02D1E6F4
Frame 04: SP = 0x088E1C10 PC = 0x02D1E8D0
Frame 05: SP = 0x088E1C28 PC = 0x02D1EA48
Frame 06: SP = 0x088E1C58 PC = 0x007F8910
Frame 07: SP = 0x088E1D58 PC = 0x007F8B80
Frame 08: SP = 0x088E1D60 PC = 0x03B6DF54
Frame 09: SP = 0x00000000 PC = 0x03B69C44
Switch uptime is 1 minute, 9 seconds
cisco WS-C2960X-48LPS-L (APM86XXX) processor (revision K0) with 524288K bytes of memory.
Processor board ID FCW1945A020
CPU rev: B
Board rev: 24
Testing DataBus...
USB EHCI 1.00
USB Console INIT
mifs[5]: mifs fsck took 0 seconds.
mifs[9]: 5 files, 2 directories
mifs[9]: Bytes used : 28050944
mifs[9]: Bytes available : 94134784
executing...
cisco Systems, Inc.
mifs[11]: 6 files, 2 directories
mifs[11]: Bytes used : 28327424
mifs[11]: Bytes available : 93858304
mifs[11]: mifs fsck took 0 seconds.
18:52:29 UTC Sat Jan 1 2000: Unexpected exception to CPUvector 2000, PC = 3B6C968
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_6
=== Flushing messages (18:52:33 UTC Sat Jan 1 2000) ===
Buffered messages:
Queued messages:
Jan 1 18:52:34.043: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:20.234: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.150: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Jan 1 18:51:54.117: in Switch 0. Cannot read pid from Flexstack module
R0 = 0x03B6C900 R1 = 0x08941C90 R2 = 0x00000000 R3 = 0x050D4620
R28 = 0x0588BB8C R29 = 0x05950000 R30 = 0x08941CD0 R31 = 0x00000000
Stack trace:
PC = 0x03B6C968, SP = 0x08941C90
Frame 00: SP = 0x08941CA0 PC = 0x03B6C900
Frame 01: SP = 0x08941CC8 PC = 0x035A0F98
Frame 02: SP = 0x08941D28 PC = 0x03626EDC
Frame 03: SP = 0x08941D38 PC = 0x02D1E6F4
Frame 04: SP = 0x08941D58 PC = 0x02D1E8D0
Frame 05: SP = 0x08941D70 PC = 0x02D1EA48
Frame 06: SP = 0x08941DA0 PC = 0x007F8910
Frame 07: SP = 0x08941EA0 PC = 0x007F8B80
Frame 08: SP = 0x08941EA8 PC = 0x03B6DF54
CPU rev: B
Board rev: 24
Testing DataBus...
USB EHCI 1.00
USB Console INIT
mifs[9]: 7 files, 2 directories
mifs[9]: Bytes used : 28603904
mifs[9]: Bytes available : 93581824
mifs[9]: mifs fsck took 31 seconds.
executing...
cisco Systems, Inc.
mifs[11]: 7 files, 2 directories
mifs[11]: Bytes used : 28603904
mifs[11]: Bytes available : 93581824
18:56:26 UTC Sat Jan 1 2000: Unexpected exception to CPUvector 2000, PC = 3B6C968
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_7
=== Flushing messages (18:56:30 UTC Sat Jan 1 2000) ===
Buffered messages:
Queued messages:
Jan 1 18:56:30.952: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:20.454: Read env variable - LICENSE_BOOT_LEVEL =
Jan 1 18:55:51.120: in Switch 0. Cannot read pid from Flexstack module
R0 = 0x03B6C900 R1 = 0x08CD03B8 R2 = 0x00000000 R3 = 0x050D4620
R28 = 0x0588BB8C R29 = 0x05950000 R30 = 0x08CD03F8 R31 = 0x00000000
Stack trace:
PC = 0x03B6C968, SP = 0x08CD03B8
Frame 00: SP = 0x08CD03C8 PC = 0x03B6C900
Frame 01: SP = 0x08CD03F0 PC = 0x035A0F98
Frame 02: SP = 0x08CD0450 PC = 0x03626EDC
Frame 03: SP = 0x08CD0460 PC = 0x02D1E6F4
Frame 04: SP = 0x08CD0480 PC = 0x02D1E8D0
Frame 05: SP = 0x08CD0498 PC = 0x02D1EA48
Frame 06: SP = 0x08CD04C8 PC = 0x007F8910
Frame 07: SP = 0x08CD05C8 PC = 0x007F8B80
Frame 08: SP = 0x08CD05D0 PC = 0x03B6DF54
Switch uptime is 1 minute, 10 seconds
CPU rev: B
Board rev: 24
Testing DataBus...
Testing Memory from 0x00000000 to 0x1fffffff.../ ▒
Mohsin Alam
RMA the switch POST is failing :
## Make sure to mark post as helpful, If it resolved your issue. ##
