mst vlans issue
tferg155
Visitor
hello everyone
I have a problem and i hope to find the solution here so i have a lab with 3 switches 1 core and 2 aggr all the switches are linked together using etherchannel and MSTP
all the switches have hosts on valns 10 20 30 40 50 60
all the informations are below in the config
MY PROBLEM IS WHY SWITCH 3 IS BLOKING THE VLAN
hosts int switch 1 and 2 can reach each other and also can reach switch 3 but SWITCH CAN NOT REACH ANY OF THEM
I WILL BE HAPPY IF SOMEONE GIVE THE SOLUTION
this is the diagram
SWITCH 1CORE CONFIG
S1(config)#do sh run
Building configuration...
Current configuration : 3153 bytes
! Last configuration change at 02:42:14 UTC Tue Sep 14 2021
version 15.1
service compress-config
hostname S1
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
no ipv6 cef
ipv6 multicast rpf use-bgp
no ip icmp rate-limit unreachable
no ip domain-lookup
ip cef
spanning-tree mode mst
spanning-tree mst configuration
name INE
revision 6767
instance 1 vlan 10, 20
instance 2 vlan 30, 40
instance 3 vlan 50, 60
spanning-tree mst 1-3 priority 24576
vlan internal allocation policy ascending
ip tcp synwait-time 5
interface Port-channel1
switchport
switchport mode trunk
interface Port-channel2
switchport
interface Ethernet0/0
duplex auto
interface Ethernet0/1
duplex auto
channel-protocol pagp
channel-group 2 mode desirable
interface Ethernet0/2
duplex auto
channel-group 1 mode desirable
interface Ethernet0/3
duplex auto
interface Ethernet1/0
duplex auto
interface Ethernet1/1
duplex auto
interface Ethernet1/2
duplex auto
interface Ethernet1/3
duplex auto
interface Ethernet2/0
duplex auto
interface Ethernet2/1
duplex auto
interface Ethernet2/2
switchport access vlan 10
switchport mode access
duplex auto
spanning-tree portfast
interface Ethernet2/3
switchport access vlan 20
duplex auto
interface Ethernet3/0
switchport access vlan 30
duplex auto
interface Ethernet3/1
switchport access vlan 40
duplex auto
interface Ethernet3/2
switchport access vlan 50
duplex auto
interface Ethernet3/3
switchport access vlan 60
duplex auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
interface Vlan30
ip address 192.168.30.1 255.255.255.0
interface Vlan40
ip address 192.168.40.1 255.255.255.0
interface Vlan50
ip address 192.168.50.1 255.255.255.0
interface Vlan60
ip address 192.168.60.1 255.255.255.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
SWITCH 2 CONFIG
S2(config)#do sh run
Current configuration : 2972 bytes
! Last configuration change at 02:42:10 UTC Tue Sep 14 2021
version 15.1
hostname S2
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
no ip domain-lookup
ip cef
name INE
revision 6767
spanning-tree mst 1-3 priority 28672
vlan 10
name IT
vlan 20
name PR
vlan 30
name HR
vlan 40
name SLAES
vlan 50
name SUPPORT
vlan 60
name SOCIAL
interface Port-channel3
switchport
switchport
duplex auto
channel-group 3 mode desirable
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
interface Vlan1
no ip address
shutdown
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
SWITCH 3 CONFIG
S3(config-if)#do sh run
Current configuration : 2935 bytes
! Last configuration change at 02:42:06 UTC Tue Sep 14 2021
version 15.1
hostname S3
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
no ip domain-lookup
ip cef
name INE
revision 6767
vlan 10
name IT
vlan 20
name PR
vlan 30
name HR
vlan 40
name SLAES
vlan 50
name SUPPORT
vlan 60
name SOCIAL
switchport
switchport
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
interface Vlan1
no ip address
shutdown
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
15 Replies 15
balaji.bandi
When you mention can reach also switch3 ? in terms of what? switch 2 and 3 as per the config only Layer2, how they can be reachable?
Due to STP, i am sure one of the Link will be BLOCK mode, you can change show spann block
You need to explain more, is the devices connected to Switch3 ports are up and running ?
Also all the switches are configured as desirable, is this intention of the test ?
BB
thanks for your replay
update the switch 3
by its self the switch 3 response to pings sometime and sometimes the ping from the core and switch 2 made it to switch 3 but switch 3 doesn't  know how to response back its very very confusing
you wrote that switch 2 and 3 are L2 how are they reachable the S2 and S3 are forwarding packet to the core why do i need them to operate at L3 even though i make them operate at level 3 still its the same am i wrong sir  ? anyway i don't know maybe my gns3 is causing the problem or the vpcs i don't know my config seems fine
about STP he is blocking the port between him and switch 2
the core switch is the primary root switch 2 is the secondary root
all the link in switch 3 are up and running
for the etherchannel i just wanted to bundle the links this not why i build this topology the desirable mode should work fine or there a problem with it too ??
thanks again sir
Hello
I dont see any mgt addressing on either of those switches, is it just the case you have negated posting that?
Regards STP, the MST estate is now ran on a per instance not per vlan so, So you should NOT be manually pruning any vlans off any trunks, also make sure all the switches have their vlan database populated correctly with all vlans ran on the MST instances.
sh etherchannel summary
sh spanning-tree mst detail
sh spanning-tree blockedports
Kind Regards
Paul
can you be more specific please
Hello
Are you manually pruning vllans off any trunks?
What ports are actually being blocked by stp , can you post this
Do you have any issues with link aggregation.
Kind Regards
Paul
hello thanks for your replay
look at this
S1(config-if)#do sh int t
Port Mode Encapsulation Status Native vlan
Po1 on 802.1q trunking 1
Po2 on 802.1q trunking 1
Port Vlans allowed on trunk
Po1 1-4094
Po2 1-4094
Port Vlans allowed and active in management domain
Po1 1,10,20,30,40,50,60
Po2 1,10,20,30,40,50,60
Port Vlans in spanning tree forwarding state and not pruned
Po1 none
S2(config-if)#do sh int t
Po3 on 802.1q trunking 1
Po3 1-4094
Po2 1-4094
Po3 1,10,20,30,40,50,60
Po3 none
S3(config-if)#do sh int t
Po1 1-4094
Po3 1-4094
 truks port are allowing 1-4094
stp is blocking port e0/0 e0/3 on switch 2
link aggregation are configured and bundle with no problem
i have 2 question
-do i need to  open int vlan 10-60 with ip addresses on all the switch or just the core switch like im doing now  is enough since the switch 2  and 3 are forwarding to the core
-and can the link aggregation cause a problem with mstp even if  its well configured ?
Hello @tferg155 ,
you have confugured Switch1 in the following manner:
name INE
revision 6767
This means that this switch is root bridge for all MST instances 1 to 3 and as a result of this:
on Switch 2 you have:
Po3 none
Each MST instance takes the same decision because the root bridge is the same for all of them.
There is nothing wrong in this. Each port-channel is seen as a single logical link by STP  ( any type inlcuding MST)
To be noted we don't know who is the root bridge of instance 0 the  IST instance but at the moment all your VLANs in use are associated to MST instances 1 to 3.
About your questions:
No the two protocols work in combination with STP that sees each bundle as a logical link and sends its BPDU out a single member link , PAGP manages each single link by sending and receiving its own L2 PDUs.
to be noted nowdays LACP is to be preferred over PAGP,
Doing it on two switches of 3 ,  and using FHRP protocols like HSRP in each VLAN would provide default gateway redundancy to end users ( the HSRP VIP is different from SVI IP addresses but it is in the same IP subnet)
For a real world network would be a true benefit in lab it can be a chance to use HSRP or VRRP or GLBP.
Edit:
check who is the root bridge for instance 0, because all MST instances are actulally packed within a single BPDU with sections for each MST instance and the BPDU is asociated to instance 0 and all other MST instances.
show spanning-tree instance 0 detail
or
show spanning-tree mst instance 0 detail
Hope to help
Giuseppe
thanks you for your replay
Youu did clear some things thank you for that but giving this config can all the end hosts ping each other or my config is not correct ? ex  end host in vlan 10 on SW2 can ping end hosts in vlan 10 on SW 1 and 3?
in my case hosts in SW 2 cant ping others hosts in SW1 and SW2 and for sec everything work fine and return to the same problem its very confusing that my problem in the first place look at thiis from SW 2
sh spanning su
Name Blocking Listening Learning Forwarding STP Active
MST0            1          0               0                13              14
MST1            1          0               0                  3                4
MST2            1          0               0                  3                4
MST3            1          0               0                  3                4
4     msts      4         0               0                22              26
for your question the root for MST0 is the SW1 is the root for all mst inst
also i read that the core switch most be the root in real world network is that true or it depand on the designee of the network
UPDATE
SW 3 en hosts now are the cant ping hots in SW1 and SW2 and SW2 and SW1 host can ping on each other this the problem may be the GNS3 ? i do know
THANK YOU AGAIN
Not sure what you mean by SW2 ad SW3 reachable ? i do not see any configuration  on the switch check can be reachble on Layer 3 ?
May be end Device can be reachbale, since it is device connected with IP.
as long as your vpc configured right VLAN IP address and Gateway, SW1 can take of routing.
BB
check the native VLAN in all three SW it must be same.
thank you for your replay
of course all the switches are in the same native  vlan 1 and its shut down so its not a native vlan problem thanks again
Friend vlan 1 which is default native vlan can not shut down.
also native vlan must be up because each mst group exchange BPDU message with each other using native vlan.
yeah true i did open the vlan 1 also the same thanks for your replay
Mohsin Alam
can you post the lab file ?
## Make sure to mark post as helpful, If it resolved your issue. ##
