07-14-2014 08:14 AM - edited 03-07-2019 08:03 PM
I've been having issues with new 2960x's on the latest code. The output of show switch will show the switch I'm consoled into with the asterisk is the master but the front panel lights show a different switch is master. Is this a bug?
07-14-2014 01:37 PM
Have you configured any priority for the master switch? if not, try giving it a higher priority and test again
07-21-2014 08:47 AM
The issue seems to be the switch that has the physical console connection is misreported or at least that's what I thought the asterisk in show switch output meant. It wasn't until I turned off every switch in the stack other than the one which hosted the console connection that I discovered this.
I always like to renumber the switches so the top switch is one and is also the master, so did change numbers and priority but the confusion stemmed from not getting an accurate report as to the switch number I was consoled into.
Thanks.
