4507 code upgrades
lcaruso
Level 6
Level 6
I need to upgrade a new 4507 and was looking for more information. Does this unit run CatOS or just IOS? Are all of the line cards needing upgrades as well as the OS? Any other info helpful.
Thanks.
Rajeev Sharma
Hey,
It should be IOS and you just need to upgrade the supervisor code.
You may upgrade by copying the image to bootflash of the switch and changing the boot variables, however if you have dual supervisor engine you may use ISSU procedure:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1/XE_330SG/configuration/guide/config/issu.html
HTH.
RS.
Rajeev Sharma
Hey,
HTH.
RS.
lcaruso
Level 6
Level 6
Thank you.
