2960x reload command issue
Vui Han Lim
Community Member
Hi Cisco,
I believe this not I'm the only one facing such issue when execute reload command
I tested 2960x as version below
normal execute reload for member or other switch by type  reload slot 2, it working fine by type reload slo 2
when I typo reload slor 2, switch dont prompt me error , but seeking confirm; In this kind situation , i just press enter because i assume i type it correctly
Surprise, it reload entire stack switch
so i test with recommend version
same issue happen, it reload entire switch stack
if we typo reload slotx 2, it still reload entire stack
please look into this issue
julijime
Hi Vui,
The behavior that you're observing is expected as you're not using the correct syntax in order to reload the slot needed.
The correct command is the following, please notice the correct keyword "slot":
SWA#reload slot 2
By typing "reload slor 2" you're telling the stack to reload all the members due to the reason "slor 2" which is used management and logging purposes.
Please see the following link for additional details on this command:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/stack_manager/command_reference/b_stck_152ex_2960-x_cr/b_stck_152ex_2960-x_cr_chapter_01.html#wp3486313748
julijime
Hi Vui,
SWA#reload slot 2
Noted, but is too dangers for me or any engineers out there reload entire stack when issue wrong command
Mark Malone
Hey that's an experimental IOS your on (EX) it will have a lot of bugs in it , you should change the IOS to an MD release and test again
The recommended image for that switch is 15.2.2E3
