2960X Stack 100% CPU
jonhill
Level 3
Level 3
We've just started to implement changes on our switches so we can use ISE for authentication and on a switch stack of 6 switches I logged on did int range gig1/0/1 - 48 and copied the below config to the switch.
Switch 1 was fine and took approximately 10 minutes to complete, Switch 2 took approximately 15 minutes but when I got to Switch 3 this took in the region of 85 minutes to complete and by the time it had completed CPU was at 100% and didn't drop.
Below is the processes and also the last 60 minute CPU history, unfortunately because we started seeing connectivty issues on the switch stack it had to be rebooted which cleared the issue.
I'm now very reluctant to carry on rolling out the config changes across the rest of our 2960X stacks just in case the same thing happens again.
Since we've had the 2960X's they've been a bit on the slow side when doing int range commands but never had this issue before.
The stack is running 15.2(2)E6.
Any help or advice would be much appreciated?
Jon
CPU utilization for five seconds: 99%/0%; one minute: 99%; five minutes: 99%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
178     2016913        8019     251516 57.85% 54.83% 53.11%   0 HRPC hrcli-event
255     2027659     2009154       1009 13.07% 19.28% 19.81%   0 Auth Manager
226     9270915    21965465        422  4.16%  1.87%  2.03%   0 HULC DAI Process
161  3496514514   945477148       3698  3.75%  3.20%  3.41%   0 Hulc LED Process
388   117720163   238809234        492  1.87%  0.44%  0.40%   0 LLDP Protocol
236     4540187    16489663        275  0.58%  0.51%  0.56%   0 IP Host Track Pr
131   289793132    37853037       7655  0.58%  0.43%  0.38%   0 hpm counter proc
233   106330513   383742152        277  0.23%  0.35%  0.34%   0 UDLD
120      238888     1029136        232  0.23%  0.28%  0.27%   0 HRPC hlfm reques
219   130242841   194137883        670  0.23%  0.15%  0.14%   0 Spanning Tree
397       16159       14165       1140  0.17%  0.14%  0.15%   0 SNMP Traps
  15   167833895    70748693       2372  0.17%  0.24%  0.54%   0 ARP Input
      111111111111111111111111111111111111111111111111111
      000000000000000000000000000000000000000000000000000999889999
      000000000000000000000000000000000000000000000000000992194944
  100 ###################################################**    *
   90 ####################################################** *#*
   80 ######################################################*###
   70 ##########################################################
   60 ##########################################################
   50 ##########################################################
   40 ##########################################################
   30 ##########################################################
   20 ##########################################################
   10 ##########################################################
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
ip access-group PERMIT-ALL in
authentication open
authentication control-direction in
authentication event fail action next-method
authentication event server dead action authorize voice
authentication event server alive action reinitialize
authentication host-mode multi-domain
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication timer inactivity server dynamic
authentication violation replace
mab
dot1x pae authenticator
dot1x timeout tx-period 10
cdp enable
lldp transmit
lldp receive
Try the following (with your security teams blessing):
no aaa authorization commands 1 default group tacacs+ if-authenticated
no aaa authorization commands 15 default group tacacs+ local if-authenticated
...and see if it improves your situation.
cheers,
Seb.
6 Replies 6
Seb Rupik
Hi there,
What do your existing aaa commands look llike?
I experienced similar behavior on some 4500 chassis a few years ago, range command would bring the switches to their knees. To get around the problem we temporarily removed the aaa authorization methods for the duration of the change window and we were then able to proceed at a good pace.
cheers,
Seb.
The existing AAA is below
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication dot1x default group ise-group
aaa authorization config-commands
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization network default group ise-group
aaa authorization auth-proxy default group ise-group
aaa accounting update newinfo periodic 2880
aaa accounting auth-proxy default start-stop group ise-group
aaa accounting dot1x default start-stop group ise-group
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group ise-group
cheers,
Seb.
Seb
That worked a treat and the difference is massive.
I'm assuming the reason those two commands cause the issue with the switch is that every command for every interface is sent to TACACS for the OK for that user so it just gets bogged down particularly if the TACACS server doesn't respond in a timely manner?
Jon
Glad to hear you're working at full rate again.
Your assumption is correct.
Like I said I have only ever seen it on the 4500 chassis switches previously, now I can add the 2960X to my list!
Cheers,
Seb.
Leo Laohoo
Raise a TAC Case.
It could be CSCvh17444.
