2960XR IOS Upgrade choices and procedure
T_tow
Quick question so I am upgrading a WS-C2960XR-48FPS-I that is currently running version 15.0(2)EX1. I want to upgrade to 15.2.6E2.  My question is should I use the .tar or .bin? Also I have not been able to find the guide for this upgrade does any have a link to it?
the upgrade is the same for each version , if your using USB you just use command --copy usb:imagename.bin to flash:
that will take it off usb and put it into flash locally unless your booting off usb .
boot system usb0:imagename.bin
then if its a .bin all you have to do is set the boot parameters in global config save and reload
boot system flash:imagename
copy run start
If your using .tar follow that guide , its same for each release of v 15
5 Replies 5
Mark Malone
the Here is the link i would read it first carefully , youc an jump to that version no isuses , .tar or .bin is a preference , .tar will use less resources on upgrade but both will work fine
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/file_management/file_management/img_files.html
So I was looking to use an usb to upgrade and was actually looking for an existing upgrade/downgrade guide for this version. Thanks for the .bin .tar clarification.
copy run start
Hers exact release for your version your going to
https://www.cisco.com/c/en/us/td/docs/switches/connectedgrid/cg-switch-sw-master/software/release/notes/rn-15-2-6e.html#32350
Upgrading the Switch Software
These are the procedures for downloading software. Before downloading software, read these sections for important information:
■Finding the Software Version and Feature Set
■Deciding Which Files to Use
■IOS/IOx Upgrade Considerations
■Archiving Software Images
■Upgrading a Switch by Using the CLI
■Installation Notes
Ok sounds good yeah I wasn't to sure if the actual install command was different but this was helpful thanks.
