33.0.0.0/8 is variably subnetted ??
Peter So
Hello all. I am doing rip route (not version 2). Why 33.0.0.0/8 is variably subnetted (photo attached) ?????
I want to conf rip #network 33.20.5.0 and #network 33.20.4.0. But it finally show #33.0.0.0 in #sh run (photo attached). Why turn to 8 bits? How can I fix it ??
I don't see any networks announced under the RIP process. You need to add:
router rip
version 2
network 33.0.0.0
no auto-summary
to all your routers. But even then you won't the see routes in the routing table, because your static routes have a lower administrative distance and take precedence. Remove all static routes and just use RIP as described above.
5 Replies 5
are you running RIPv2 ?
router rip
--> version 2
Otherwise, post the zipped Packet Tracer project (.pkt) file here as an attachment...
Reply to Georg Pauwen
I am not use RIP v2. I have attached the zip file here. Thank you
router rip
version 2
network 33.0.0.0
no auto-summary
Thank you!! I solved the problem.
