3500 Serious Switches
n.abeysekara
Hi Guys..!!
Where can I find the flash slot in 3500 serious switches...??? I can see only ICs and wires only...
Flash memory upgrade is not possible on 3500 switch. In fact you dont need to as the IOS supplied even the most recent IOS fits fine.
Hope this helps......
Shaheen
5 Replies 5
Marvin Rhoads
There is none. The flash memory is internal to the switch and not an externally-accessible slot.
See http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst3550/hardware/installation/guide/35OVERVU.html
Hey..MARVIN,
Thanks for the information buddy...Bt can u tell me how to upgrade the flash memory of a switch..and where can I find the flash in a switch.....
Shaheen
Hey..!! Shaheen,
Thanks buddy..Nw Im get cleared...
Best regards
Nuwan
Hi Nuwan,
you are welcome !!!
In my view this forum is a great place to learn, ask and teach.... I have learned a lot from here.
thanks for the rating.
Shaheen
