3500xl switch will not accept interface range
philsvoice
I get a invalid input  range
   &nbSwPodx(config)# SwPodx(config)#int SwPodx(config)#interface range fastethernet 0/2 - 24
                                                          ^ % Invalid input detected at '^' marker. SwPodx(config)#sp;
20 Replies 20
Looks like in for a lot of work arounds and trouble with this switch,  what is the next level switch that will support the lastest ios commands,  also would GNS3 be a better option, because this just lab 3 in the book and im spending to much time reshearching.
This is a voice lab and think I will be using Ip Phone and PC together.
vlan 10 is Data for PC
vlan 15 is Voice for IP Phone
vlan 11 is Management for gateway
Maybe this is why I have to assign 0/2 - 24 to vlan 10 and 15
correct ??
my vlan config for 3500xl switch is
vlan
name Data 10
vlan
name Management 11
vlan
name Voice 15
interface fa0/1
switchport trunk encapsualtion dot1q
switchport mode trunk
___
I need to imput range below, what is the quickest way.  Thanks
int range 0/2 -24
switchport mode access
switchport access vlan 10
switchport access vlan 15
As you are looking for your home lab then u must be looking for cheap Switch: Then go fo 3560.
Then you can configure:
Fa0/1
switchport voice vlan 15
I think that this switch will support Interface range feature. Then you can configure all interface at once.
More about config:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swvoip.html
Rgerads
This is a voice lab and think I will be using Ip Phone and PC together.  vlan 10 is Data for PC vlan 15 is Voice for IP Phone vlan 11 is Management for gateway Maybe this is why I have to assign 0/2 - 24 to vlan 10 and 15 correct ??    my vlan config for 3500xl switch is vlan name Data 10 vlan name Management 11 vlan name Voice 15 interface fa0/1 switchport trunk encapsualtion dot1q switchport mode trunk ___ I need to imput range below, for each port 02 - 24, because its vioce lab, AM i correct,  once i get pass this I should be ok I hope.  Thanks for the help int fa0/2 Switch(config-if)#switchport trunk encapsulation dot1q Switch(config-if)#switchport mode trunk Switch(config-if)#switchport voice vlan 10 Switch(config-if)#spanning-tree portfast int fa0/2 Switch(config-if)#switchport trunk encapsulation dot1q Switch(config-if)#switchport mode trunk Switch(config-if)#switchport voice vlan 15 Switch(config-if)#spanning-tree portfast
Jon Marshall
Phillip
See this thread for how to configure each port. Because the switch is quite old people have reported using the "switchport voice vlan x" command did not work.
So you can see the solution in the following thread -
https://supportforums.cisco.com/thread/2181858
note that you will have configure each port one by one because there is no "range" option on your switch.
Jon
Looks like in for a lot of work arounds and trouble with this switch,  what is the next level switch that will support the lastest ios commands,  also would GNS3 be a better option, because this just lab 3 in the book and im spending to much time researching.  thanks
correct ??
vlan
name Data 10
vlan
name Management 11
vlan
name Voice 15
interface fa0/1
___
int range 0/2 -24
philsvoice
Looks like in for a lot of work arounds and trouble with this switch,  what is the next level switch that will support the lastest ios commands,  also would GNS3 be a better option, because this just lab 3 in the book and im spending to much time reshearching.  pease advise this switch will work for a voice lab, This is a voice lab and think I will be using Ip Phone and PC together.
vlan name Data 10
vlan name Voice 15
___ I need to imput range below, what is the quickest way since this switch (3500xl) doesnt support the Int range command
will this work
int range 0/2  to 24
Switch(config-if)#spanning-tree portfast.
int 0/2  to 24
Switch(config-if)#spanning-tree portfast the range command.
do this for each port 2 t0 24?
