3560-CX series PD not negotiating UPOE/AT
kdavison007
I have an 8 port 3560-CX that is powered over the uplink ports.  I have it connected to a 4510 with a UPOE module.  The compact switch initially boots with 15.4 watts and eventually hits a check where it tries to negotiate more power to continue booting.  However, it hangs here.  If I plug in the DC power it will see the additional power and boot up fine.  Once booted, I can unplug the DC power brick and it will pull 60 watts from UPOE.  However, during boot it cannot seem to negotiate anything beyond 15.4 watts.  I do have CDP enabled.
Reza Sharifi
You may want to try to set the port on the 4510 statically for the 60 watts you need and test again.
power inline consumption 60000
