3560 policy based routing verify-availability
mukremin13
Cisco 3560 does not support "set ip next-hop verify-availabilty". I need this command in my config. "set ip next-hop"  do not do the same job.
What can i do?
any other related command in replace of it?
8 Replies 8
danbowencisco
Hi There,
It does support it, I have it on my 3560G.
What version of code are you running?
Dan
SW version 12.2.(50)SE3
Sw image C3560-IPSERVICESK9-M
and switch hardware 3560v2
ok, upgrade to the following as you can see that it is supported on my 3560G
route-map PBR-Management permit 30
match ip address Route-Map-ACL-Management-Process3
set ip next-hop verify-availability 10.11.120.161 1 track 30
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:44 by prod_rel_team
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
SL-Cisco-3560G-SW uptime is 12 hours, 36 minutes
System image file is "flash:c3560-ipservicesk9-mz.122-58.SE2.bin"
Yes in my ios there is also this config shown. But when i insert another sequence like
"route-map PBR-Management permit 40", debug says unsupported.
Do you have many sequence with the same name. Like
route-map PBR-Management permit 50
And is it running correctly?
And also this link says set ip next-hop verify-availability is not supported.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_58_se/configuration/guide/swuncli.html
yes I do jave the sequence, as shown below - one problem I am having is getting the route map on the interface as it allows the command but doesnt show the route map in the config.
route-map PBR-Management permit 10
match ip address Route-Map-ACL-Management-Process1
set ip next-hop verify-availability 10.11.120.161 1 track 610
route-map PBR-Management permit 20
match ip address Route-Map-ACL-Management-Process2
set ip next-hop verify-availability 10.11.120.161 1 track 620
set ip next-hop verify-availability 10.11.120.161 1 track 630
match ip address Route-Map-ACL-Management-Information
set ip next-hop verify-availability 10.11.120.161 1 track 640
match ip address Route-Map-ACL-Management-Supervisory
set ip next-hop verify-availability 10.11.120.161 1 track 650
same problem with me i think.
I have also do these. But when show running config, there is no ip policy route-map command. And when typing show ip policy it is blank.
when you connect via serial port, and open the "debug ip policy" and set another sequence to the PBR-Management
you have also see unsupported messaage.
any update daniel
anyone help me?
