3560 reboot delay
ranginroshkg
Hi all,
I have a 3560 switch with version -(C3560-IPBASE-M), Version 12.2(25)SEB2.
whenever I reboot the switch it will take 20 minitues to come into normal mode. Upto 20 minitues the "sys" LED will be blinking. I tried upgrading IOS still I'm getting same issues. Anybody can help ??
royalblues
Level 11
Level 11
Do you see it stuck at a particular point during the post when logged on via console?
Whenever I try to reboot it shows the messages below and stucks there.
Base ethernet MAC Address: 00:14:1c:9b:ab:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 1718 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 12215808
flashfs[0]: Bytes available: 20298240
flashfs[0]: flashfs fsck took 13 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
