3560 Redundancy
gagamboy15
Level 3
Level 3
Hi Guys,
I have a new 2x 3560, do you have any suggestion on how can I make this redundant? Like you will just see 1 node for this two switches. I have configured an etherchannel on it but it seems it is not working.
interface GigabitEthernet0/1
channel-group 1 mode auto
switchport mode trunk
interface GigabitEthernet0/2
Any help is very much appreciated. Thanks in advance.
Cheers!
2 Accepted Solutions
Tshi M
Level 9
Level 9
what do you get when you do:
sh ether sum
what do you see in the log?
At the very basic, i will have:
po1
g0/1
channel-group 1 mode desirable
g0/2
Irvine
Can you post full configs for both switches.
if you want to connect the 2 switches togther with an etherchannel trunk
SW1(config)# int range gi0/1 - 2
SWI(config-if)# switchport
SWI(config-if)# switchport trunk encapsulation dot1q
SWI(config-if)# switchport mode trunk
SW1(config-if)# channel-group 1 mode on
do same config as above for SW2
Connect the 2 switches together on gi0/1 & 2.
3560 will run HSRP/GLBP. This is used for gateway redundancy. So an example
SW1
int vlan 10
ip address 192.168.5.2 255.255.255.0
standby 10 ip 192.168.5.1
standby 10 pri 110
standby 10 preempt
standby 10 auth
SW2
ip address 192.168.5.3 255.255.255.0
standby 10 pri 100
standby 10 auth
then any client in vlan 10 is given the default-gateway of 192.168.5.1
Jon
8 Replies 8
Jon Marshall
Irvine
What do you mean by redundant. Do you mean connect them togther with etherchannel and perhaps run HSRP between the 2 switches ?
Can you post output of
"sh etherchannel summary" &
"sh int trunk"
from both switches.
Jon
Hi Jon,
Yes, you're right. But I don't think 3560 supports HSRP, Is there any protocol or way for redundancy.
Please see attachment. Thanks.
Irvine
SW1
int vlan 10
standby 10 pri 110
standby 10 preempt
standby 10 auth
SW2
standby 10 pri 100
standby 10 auth
Jon
Your first mentioned that both g0/1 and g0/2 are part of the po1 ether but your attachment shows that g0/1 belongs to po1 and g0/2 belongs to po2.
Tshi M
Level 9
Level 9
sh ether sum
po1
g0/1
g0/2
Hi Guys,
Thanks for the feedback. It seems that I misconfigured the port channel mode and PO1 and PO2 group for both switches.
By the way is it advisable to do port-channel mode ON on both switches? or should I stick to auto-desirable?
Is there any another way to do redundancy aside from HSRP?
Thanks to you guys!
Cheers!
I will use mode on prevents negotiation and might a safe bet.
regards
Using 'port-channel mode on' means just what it says; there will be no negotiation. I use it because it is quicker. If you use it, you must always be certain that all ports you intend to physically connect are correctly configured BEFORE connecting them. Otherwise, you could wind up with a looping condition that could do some pretty nasty things on your network.
