3560 sw question
dave dave
hi! we've a few 3560 sw that run on flat network. Here's the config on one of the switch. Can i create another vlan eg. vlan10 in this switch as a backup vlan? I do not wish to add more vlans except the backup vlan10 and vlan10 do not need to be routable. The current clients shd still run on flat network (eg. in gi0/47). Will adding vlan10 in some of the unused ports affect the current operation? Thanks.
interface GigabitEthernet0/47
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/48
interface GigabitEthernet0/49
switchport mode trunk
channel-group 1 mode desirable
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
ip address 10.20.50.6 255.255.255.0
ip default-gateway 10.20.50.1
5 Replies 5
fgasimzade
Level 4
Level 4
What do you mean by "backup vlan"?
Basically, adding a new vlan will not affect current users.
Jon Marshall
No ti wouldn't affect current operation.
So to create vlan 10 at L2 -
3560(config)  vlan 10 name v10
this will now allow you to allocate ports into vlan 10 eg.
int gi0/10
switchport access vlan 10
Jon
fgasimzade
Level 4
Level 4
If you dont want this vlan to be routable, do not create interface vlan 10. PC's in vlan 10 will only see each other, but will not communicate with vlan1
hi! The objective is to use a different IP range and vlan for my servers to run backup job. Each additional NIC card in my servers will be assign a different IP range which is different from my production ip range. Will this work. Thanks.
Will this work.
Yes
