3560 VLAN Management
Dear Gurus,
How to change the management vlan for 3560? I cant ping it on other routers, maybe the default route is wrong?
Router-Gig0/010.1.1.1----------Gig0/1-VLAN100-10.1.1.2
vlan 2-5,523,889,1000,2000
int Gig0/1
description [To-Router]
switchport access vlan 100
interface Vlan1
no ip address
shutdown
interface Vlan100
ip address 10.1.1.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.1.1.1
5 Replies 5
Mark Yeates
Level 7
Level 7
It appears that you have not created the layer 2 vlan on the switch.
switch#conf t
switch(config)# vlan 100
switch (config-vlan)# exit
HTH,
Mark
Ganesh Hariharan
Dear Gurus,
int Gig0/1
interface Vlan1
no ip address
shutdown
interface Vlan100
Are you able to ping fromconnected router port and pls paste the show vlan output and show int vlan 100
Ganesh.H
Hi Ganesh,
Yes i can ping from the connected router, thats why im thinking of the default route.
#sh interfaces vlan100
Vlan889 is up, line protocol is up
  Hardware is EtherSVI, address is 0019.06c4.81c4 (bia 0019.06c4.81c4)
  Internet address is 10.1.1.2/24
  MTU 1522 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     3272 packets input, 214296 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicast)
     2763 packets output, 294448 bytes, 0 underruns
     0 output errors, 0 interface resets
OK then from other router is the route to your management vlan should be dropped towards your router, I mean to say
if R2---R1--(management vlan)switch. R2 should have route for management vlan towards R1 interface,just check it.
and from R2 traceroute the mgmt vlan ip also .
Ganesh.H
glen.grant
   The answer was already given by Mark . The layer 2 vlan is not created so it does not have a path  to the router.  Notice there is no vlan 100 created , not going to work without it .
