10-25-2018 04:10 PM - edited 03-08-2019 04:28 PM
I have an older IOS on a 3560X and for cyber vulnerabilies, I would like to upgrade to the latest stable and supported IOS. We are currently running c3560e-universalk9-mz.122-55.SE5.bin. It seems that I am restricted from downloaded newere universal images (Additional entitlement required). I was hoping someone may know what would be the latest 2018 version of IOS I could load into this unit? I am doing SSH/SNMPv3 so not certain which IPBASE or UNIVERSAL I should use. Any help would be greatly appreciated!!
Brett
10-25-2018 05:52 PM
Hi Brett,
Please click in the below link I am sending to you, You will find the information you are looking for!
Please rate it if it helps, thank you.
regards,
Ben
10-25-2018 09:58 PM
10-26-2018 06:53 AM
Hi Leo, thank you for your response! May I ask why you recommend this? The reason I am asking is we are doing some Cyber remediation work and want to eliminate as many vulnerabilities as possible. From a security standpoint and this additional background, do you still suggest sticking with this train?
Thank you!
Brett
10-26-2018 03:05 PM
Because 12.2(55)SE train is the most stable IOS that Cisco has ever released. Even the later ones, even from different platforms, cannot match the stability of this version.
10-26-2018 01:18 PM
i would still stick with latest 12.2.55-SE12 - it support SSH and SNMPv3
