3560-X with LAN Base
Hi guys
I have 3560X with LAN Base software. And I cannot do routing between vlans. Static routing is not possible too because don't have ip route command.
I need the IP Base. My question is, why I will buy a 3560X with LAN Base if this switch don't make L3 routing? In this case is better purchased a 2960.
Best Regards
Peterson
TarasKotov
You lower your CAPEX and have an ability to make L3 switch in a future without buying new equipment.
Also you can upgrade 3560-X to IP Services with more L3 features like PBR.
Here is info about Catalyst 3650-X: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733_ps10744_Products_Data_Sheet.html
TarasKotov
Thanks Taras!
