08-18-2011 11:26 AM - edited 03-07-2019 01:46 AM
I am configuring a PoE 3560 and it seems to think that it is a non-PoE model. When I first put the switch in, I plugged a few phones into it. They powered up, registered, etc. I received a call a few days later saying none of the phones would power up. I noticed the "power-deny" message on the ports and also noticed that the switch listed available power as 0.0w. Rebooting the switch didn't correct anything. The switch is in an air-conditioned environment and doesn't seem to have any temperature issues when I look at the temps. I think it may be a bad power supply but I wanted to run it by everyone before contacting TAC because it seems to be powering the switch itself just fine and hasn't gone out completely. The log on the switch didn't reveal any useful errors either.
Here is a copy of the "sh ver" command and a copy of the "sh power inline" command:
Cisco IOS Software, C3560E Software (C3560E-UNIVERSAL-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 17:18 by nachen
Image text-base: 0x00003000, data-base: 0x01600000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3)
MAINT-WAREHOUSE-3560-24 uptime is 6 minutes
System image file is "flash:c3560e-universal-mz.122-35.SE5/c3560e-universal-mz.122-35.SE5.bin"
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C3560E-24PD (PowerPC405) processor (revision M0) with 122880K/8184K bytes of memory.
Processor board ID FDO1509Y1FP
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : B8:BE:BF:52:43:00
Motherboard assembly number : 73-11180-14
Motherboard serial number : FDO15100Q99
Model revision number : M0
Motherboard revision number : B0
Model number : WS-C3560E-24PD-S
Daughterboard assembly number : 800-29737-01
Daughterboard serial number : FDO1510024N
System serial number : FDO1509Y1FP
Top Assembly Part Number : 800-28932-04
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : COMCK00ARB
Hardware Board Revision Number : 0x00
Switch Ports Model SW Version SW Image
* 1 30 WS-C3560E-24PD 12.2(35)SE5 C3560E-UNIVERSAL-M
Configuration register is 0xF
MAINT-WAREHOUSE-3560-24#sh power inline
Available:0.0(w) Used:0.0(w) Remaining:0.0(w)
Interface Admin Oper Power Device Class Max
(Watts)
Gi0/5 auto off 0.0 n/a n/a 15.4
Gi0/6 auto off 0.0 n/a n/a 15.4
Gi0/7 auto off 0.0 n/a n/a 15.4
Gi0/8 auto off 0.0 n/a n/a 15.4
Gi0/9 auto off 0.0 n/a n/a 15.4
Gi0/10 auto off 0.0 n/a n/a 15.4
Gi0/11 auto off 0.0 n/a n/a 15.4
Gi0/12 auto off 0.0 n/a n/a 15.4
Gi0/13 auto off 0.0 n/a n/a 15.4
Gi0/14 auto off 0.0 n/a n/a 15.4
Gi0/15 auto off 0.0 n/a n/a 15.4
Gi0/16 auto off 0.0 n/a n/a 15.4
Gi0/17 auto off 0.0 n/a n/a 15.4
Gi0/18 auto power-deny 0.0 n/a n/a 15.4
Gi0/19 auto off 0.0 n/a n/a 15.4
Gi0/20 auto off 0.0 n/a n/a 15.4
Gi0/21 auto off 0.0 n/a n/a 15.4
Gi0/22 auto off 0.0 n/a n/a 15.4
Gi0/23 auto off 0.0 n/a n/a 15.4
Gi0/24 auto power-deny 0.0 n/a n/a 15.4
Solved! Go to Solution.
08-18-2011 01:15 PM
Could you try shut/no shut on any one port & see if that resolves the issue for you? There was a bug similar to this & workaround was shut/no shut
If that still doesn't resolve the issue, I would look at "show post" to verify that whether the inline power supply is ok or not?
If it is faulty, you will see following o/p in "show post"
POST: Inline Power Controller Tests : Begin
POST: Found inline power controller write failure, inst 1
POST: Inline Power Controller Tests : End, Status Failed
& if that's the case, you will need to get it replaced.
Amit
08-18-2011 11:36 AM
Helo Kyle,
Strange issue indeed. Do you believe you could upgrade to a more recent IOS version before performing any other experiments? The one you are running right now is quite outdated. The most recent version should be 15.0(1)SE or its immediate predecessor, 12.2(58)SE2.
Best regards,
Peter
08-18-2011 01:15 PM
Amit
08-26-2011 07:26 AM
Thanks. The POST showed a failed power controller. I got it RMAed.
08-18-2011 04:05 PM
Can you post the "sh run int Gi0/18 "? Maybe someone's disabled PoE? Or maybe the power end-point device require >15.4w?
08-19-2011 02:52 AM
If you have physical access to the switch can you please select the PoE mode via the "MODE" button and post the state of the PoE LED. Also will you please post the outputs from "sh int Gi0/18" ("sh int Gi0/24") and "sh env power" commands.
Thanks & Regards,
Antonin
