3560g not routing?
sidovskiy
How to get on default-gateway 192.168.100.80 of another network GigabitEthernet0/2 or GigabitEthernet0/3.
Not ping from 192.168.112.200 to 192.168.100.80
from CISCO ping 192.168.100.80 OK...
what is?
no aaa new-model
clock timezone UTC 3
ip subnet-zero
ip routing
no ip domain-lookup
ip name-server 192.168.100.10
ip name-server 192.168.100.15
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
bridge irb
interface GigabitEthernet0/1
no switchport
ip address 192.168.100.1 255.255.255.0
bridge-group 1
interface GigabitEthernet0/2
no switchport
ip address 192.168.112.1 255.255.255.0
bridge-group 1
interface GigabitEthernet0/3
no switchport
ip address 192.168.113.1 255.255.255.0
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
ip default-gateway 192.168.100.80
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.100.80
ip http server
ip http secure-server
control-plane
bridge 1 protocol vlan-bridge
bridge 1 route ip
bridge 1 priority 100
line con 0
line vty 0 4
password iluminate
no login
line vty 5 15
password iluminate
no login
ntp clock-period 36030260
ntp server 192.168.100.10
end
#sh ip route
C 192.168.112.0/24 is directly connected, GigabitEthernet0/2
C 192.168.100.0/24 is directly connected, GigabitEthernet0/1
C 192.168.113.0/24 is directly connected, GigabitEthernet0/3
S* 0.0.0.0/0 [1/0] via 192.168.100.80
5 Replies 5
mark.edwards
Hi, Have you enabled "ip routing"?
spremkumar
Level 9
Level 9
Can you check whether you have a route for
192.168.112.200 in 192.168.100.80 ?
If 192.168.100.80 is a cisco device then check using show ip route for the ip from which you are trying to ping.
regds
Sureshdank
I think this is because of interface briding.
As there are no vlans configured on your switch then why you are using briding protocol as vlan-bridge. I think you should use ieee protocol.
And for routing you can also create vlans and do inter-vlan routing (no need to make physical interfaces as L3).
Suresh
ip routing enable
pc ping pc1..ok
pc1 ping PC..ok
pc ping proxy...ok
pc1 ping proxy...not ping
Two things i would suggest here is to check for windows firewall but since your PC is able to ping proxy thats negated the only thing may be the unavailability of route for 192.168.112.200(PC1) on your proxy.
if its on Windows platform try to add a route using route add command for the network 192.168.112.0 or a host specific route for the particular ip 192.168.112.200 and check.
i feel that should solve your problem..
regds
