10-31-2006 04:16 AM - edited 03-05-2019 12:32 PM
Hey folks.
I have an 871 with 128Mb of DRAM and 24Mb of Flash. I was running 12.4.9T1 Advanced Security and wanted to test out the 12.4.9T1 Advanced IP Services image. The IOS .bin file for Adv Security is 13.6Mb, and AdvIPServ is about 16Mb.
The requirements for AdvIPServices inidcates that you need 28Mb of Flash, but since the image was only 16Mb, I figured I'd give it a shot. Upon reboot, the router started spitting out really strange garbage characters, and although it seems to go through the boot process it appears that it doesn't like the AdvIPServices image, even though there appears to be plenty (8mb) of flash left over for it. (I did an 'erase flash' beforehand, so the only thing there is the IOS .bin image.)
Any thoughts?
Thanks!
- Neil
Solved! Go to Solution.
10-31-2006 04:20 AM
Hi Neil
If possible and if you are in normal router prompt can you issue show version command check the filename with which the router has booted ?
Also are you facing any problem with the new ios ?
regds
10-31-2006 04:20 AM
Hi Neil
regds
10-31-2006 05:34 AM
This was really strange. Again, the problem was that I was getting garbage characters on my HyperTerminal when I was console'd into the router. I scanned through the Cisco TAC case collection, and found a tip to try setting your HyperTerm to different port speeds, instead of the default 9600. I was finally able to get in when I tried 115200 (same N,8,1, though.)
The boot register was set to 0x3922, but once I rebooted it returned to 0x2102.
It appears that the AdvIPServices IOS image is working fine with only 24Mb of Flash, so I guess my question still remains: Why would the Cisco site say 28Mb of Flash is required when the image is only 16Mb?
Here's the show ver from 871:
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(9)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 30-Aug-06 22:34 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
BURMARTR uptime is 3 minutes
System returned to ROM by reload at 14:56:16 EST Mon Oct 30 2006
System image file is "flash:c870-advipservicesk9-mz.124-9.T1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 871W (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
1 802.11 Radio
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
