3650 Boot Problem
Adan Suris
Community Member
When i trying to boot my cisco 3650 IOS (CAT3K_CAA-HBOOT-M) Version 1.2
The switch send me this message:
Stack Adapter Auth Fail : SIF_SERDES_CABLE_EASTBOUNDDec 13 16:42:17 %STACKMGR-1-UNKNOWN_STACK_ADAPTER: Unknown stack adapter inserted on stack port 1 on switch 1
*** Stack adapter authentication failed on stack port 2 on switch 1 ***
Stack Adapter Auth Fail : SIF_SERDES_CABLE_WESTBOUND
Booting...Initializing RAM +++++++@@@@@@@@...++++++++++++++++++++++++++++++++
Base ethernet MAC Address: 88:5a:92:5d:3b:00
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 2 seconds....done Initializing Flash.
Getting rest of image
Reading full image into memory....done
Reading full base package into memory...: done = 79113792
Nova Bundle Image
Kernel Address    : 0x6042d350
Kernel Size       : 0x402ecf/4206287
Initramfs Address : 0x60830220
Initramfs Size    : 0xdb9420/14390304
Compression Format: .mzip
Bootable image at @ ram:0x6042d350
Bootable image segment 0 address range [0x81100000, 0x82110000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x81653a10 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
*** Stack adapter authentication failed on stack port 1 on switch 1 ***
Stack Adapter Auth Fail : SIF_SERDES_CABLE_EASTBOUNDDec 13 16:46:17 %STACKMGR-1-UNKNOWN_STACK_ADAPTER: Unknown stack adapter inserted on stack port 1 on switch 1
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.01SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 05-Dec-13 10:15 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
<Sat Dec 13 16:47:49 2014> Message from sysmgr: Reason Code:[2] Reset Reason:Service [fed] pid:[5664] terminated abnormally [6].
Details:
Service: fed
Description: Forwarding Engine Driver
Executable: /tmp/sw/mount/cat3k_caa-platform.SPA.03.03.01SE.pkg//usr/binos/bin/fed
Started at Sat Dec 13 16:45:43 2014 (997426 us)
Stopped at Sat Dec 13 16:47:49 2014 (813793 us)
Uptime: 2 minutes 6 seconds
Start type: SRV_OPTION_RESTART_STATELESS (23)
Death reason: SYSMGR_DEATH_REASON_FAILURE_SIGNAL (2)
Last heartbeat 0.00 secs ago
PID: 5664
Exit code: signal 6 (no core)
CWD: /var/sysmgr/work
PID: 5664
UUID: 3005
6 Replies 6
InayathUlla Sharieff
Could you remove the stack cables and try to boot?
The switch actually no have any stack cable installing.
I have same problem . here is the log:
*Apr 1 05:58:53.183: %STACKMGR-1-UNKNOWN_STACK_ADAPTER: 1 stack-mgr: Unknown stack adapter inserted on stack port 1 on switch 1 *** Stack adapter authentication failed on stack port 1 on switch 1 ***
whereas the stack cable was installed
does the adapter / cable was broken?
i have the same problem running 16.0.3.07 in install mode.
Bundle Image
Kernel Address    : 0x5342f388
Kernel Size       : 0x34e9ec/3467756
Initramfs Address : 0x5377dd74
Initramfs Size    : 0x119e33d/18473789
Compression Format: mzip
Bootable image at @ ram:0x5342f388
Bootable image segment 0 address range [0x81100000, 0x81b8adc0] is in range [0x8        0180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@        @@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x816903a0 ...
Final tar file: mcu_ucode_bundle_8_1_0.tar
Both links down, not waiting for other switches
Switch number is 1
do any one know fix for this problem?
the switch is not in stack setup and no stack cabel are in
I'm also having the same problem with 3650s running 16.3(8) code.  Then again, half my switch stacks are working perfectly and half are not.  I'm only running two models of switch and can't find any discernible pattern to why some work and some don't.  Here's the full error from my boot loop:
Booting...
Interface GE 0 link down***ERROR: PHY link is down
Reading full image into memory...Check base package header ...: done = 16384
Reading full base package into memory...: done = 22306936
Bundle Image
Kernel Address : 0x53430388
Kernel Size : 0x34ec3d/3468349
Initramfs Address : 0x5377efc5
Initramfs Size : 0x119e8b3/18475187
Bootable image at @ ram:0x53430388
Bootable image segment 0 address range [0x81100000, 0x81b8adc0] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x816903c0 ...
Jul 10 15:31:57.276 R0/0: %PMAN-3-PROCHOLDDOWN: The process sif_mgr has been helddown (rc 134)
Jul 10 15:31:57.848 R0/0: %PMAN-0-PROCFAILCRIT: A critical process sif_mgr has failed (rc 134)
Jul 10 15:31:58.351 R0/0: %PMAN-3-RELOAD_RP: Reloading: Switch will be reloaded
Chassis 0 reloading, reason - Non participant detected
Jul 10 15:32:09.243 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: reload fp action requested
Jul 10 15:32:19.666 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: rp processes exit with reload switch code
Jul 10 15:32:37.753 R0/0: %PMAN-3-PROCESS_NOTIFICATION: System report /crashinfo/system-report_local_20190710-153232-Universal.tar.gz (size: 5614 KB) generated
octeon_wdt: WDT device closed unexpectedly. WDT will not stop!
reboot: Restarting system
Did anyone find a solution to this problem?
