3650 IP vs LAN base in a stack
nmoore1978
I have an existing 3650 with IP Base license.  It's configured with EIGRP.  I need to add a 2nd switch and make it a stack.  Does the 2nd switch need to have IP Base license also, or will a LAN Base unit suffice?  Will the 2nd switch inherit the master switch's license?
Just curious if it's possible to save a little money.
Reza Sharifi
You need the same license level for the whole stack
see Q&A
Q. What are the license requirements for a Cisco Catalyst 3650 switch stack? A. In a Cisco Catalyst 3650 stack, all switches should be at the same image-based license (IP Services/IP Base/LAN Base) level. The active switch license level is considered as the reference, and the member switch licenses are compared against it. If there is a mismatch, the active switch with the syslog message “license mismatch error” indicates that the stacking was unsuccessful.
Link
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/q-and-a-c67-729531.pdf
Reza Sharifi
see Q&A
Link
Excellent.  Thanks!
