3650 Stack Upgrade Questions
Quintin.Mayo
Level 5
Level 5
I just prepped a 3650 stack and completed the upgrade procedures. My question is when I reviewed the flash after the install it shows the new pkg files for the image cat3k_caa-universalk9.16.12.07.SPA.bin for the date on the install. But the packages.conf file shows a older date then the pkg files.  Is this because I haven't reloaded the device yet? I repeated the upgrade and the results are the same.  Any insight on this would be greatly appreciated.
77447 -rw- 20097668 Sep 2 2022 13:41:51 -04:00 cat3k_caa-guestshell.16.12.07.SPA.pkg
77451 -rw- 32795564 Sep 2 2022 13:42:29 -04:00 cat3k_caa-rpbase.16.12.07.SPA.pkg
77448 -rw- 400857724 Sep 2 2022 13:42:22 -04:00 cat3k_caa-rpcore.16.12.07.SPA.pkg
77450 -rw- 3414660 Sep 2 2022 13:42:25 -04:00 cat3k_caa-srdriver.16.12.07.SPA.pkg
77445 -rw- 4780 Sep 2 2022 13:42:53 -04:00 cat3k_caa-universalk9.16.12.07.SPA.conf
12 -rw- 1244 Dec 6 2016 14:51:25 -05:00 packages.conf
11 drwx 4096 Dec 26 2020 19:02:24 -05:00 dc_profile_dir
31 -rw- 2097152 Sep 2 2022 13:46:53 -04:00 nvram_config
77446 drwx 4096 Jun 27 2021 05:32:45 -04:00 core
29 drwx 4096 Jul 6 2018 11:26:22 -04:00 onep
85188 -rw- 1516 Aug 24 2022 15:43:00 -04:00 vlan.dat
77449 -rw- 23018112 Sep 2 2022 13:42:25 -04:00 cat3k_caa-webui.16.12.07.SPA.pkg
14 -rw- 111 Dec 26 2020 19:02:11 -05:00 bootloader_evt_handle.log
19 -rw- 15954556 Mar 21 2018 06:31:06 -04:00 cat3k_caa-guestshell.16.03.05b.SPA.pkg
20 -rw- 22301472 Mar 21 2018 06:31:06 -04:00 cat3k_caa-rpbase.16.03.05b.SPA.pkg
21 -rw- 266035828 Mar 21 2018 06:31:07 -04:00 cat3k_caa-rpcore.16.03.05b.SPA.pkg
22 -rw- 9089660 Mar 21 2018 06:31:07 -04:00 cat3k_caa-srdriver.16.03.05b.SPA.pkg
23 -rw- 212812400 Mar 21 2018 06:31:16 -04:00 cat3k_caa-wcm.16.03.05b.SPA.pkg
24 -rw- 13423224 Mar 21 2018 06:31:16 -04:00 cat3k_caa-webui.16.03.05b.SPA.pkg
85187 drwx 4096 Jun 27 2021 05:16:45 -04:00 .prst_sync
18 drwx 4096 Mar 21 2018 07:08:49 -04:00 .rollback_timer
26 drwx 4096 Mar 21 2018 07:08:57 -04:00 gs_script
27 -rw- 65301 Dec 26 2020 19:02:41 -05:00 memleak.tcl
28 drwx 4096 Mar 21 2018 07:09:26 -04:00 .installer
16 -rw- 2097152 Sep 2 2022 13:46:53 -04:00 nvram_config_bkup
1621966848 bytes total (511504384 bytes free)
Directory of flash:/*.conf
Leo Laohoo
This is a known "feature" with IOS-XE.  During the unpacking stage, there would have been an error message (WARNING) that the packages.conf file could not be overwritten.
The fix is very simple:
rename flash:packages.conf flash:packages.conf.00-
rename flash:cat3k_caa-universalk9.16.12.07.SPA.conf flash:packages.conf.00-
Please see Cisco 3850: IOS-XE/Firmware Upgrade and scroll down to the "Gotcha" section.
