4500x
cwbrown
Frequent Visitor
Frequent Visitor
Can I perform ISSU from :cat4500e-universalk9.SPA.03.11.00.E.152-7.E.bin,1  to cat4500e-universalk9.SPA.03.11.06.E.152-7.E6.bin without a step? Can I go from one straight to the other?
balaji.bandi
I personally suggest to use traditional way, rather issue.
is ths dual sup ? and VSS ?
I do not see any issue, sicne this is same train of code, until you see bugs associated with the version and understand the caveats you good to go.
BB
yes. check below documents and verify everything is ready.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/issu.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-311xe-4500x.html#id_100898
Good luck
KB
balaji.bandi
BB
Leo Laohoo
Never, ever, believe in the hype about ISSU, FSU/eFSU.
ISSU, FSU/eFSU do not (always) work in production -- It will work in a "lab" environment but, in the wild, it normally fails most of the time.
