3650 Switch Stack member issue
gkurunthasalam
Frequent Visitor
Frequent Visitor
We have 2 3650 switches in stack. i m unable to login standby stack member (switch2) using command "session" as advised in documents.
Please advise how to login standby/stack members from active switch and commands.
IOS  - Denali 16.3.5 IOS versions - ipservicesk9 - WS-C3650-48PD
regards
Gokul K
Julio E. Moisa
It should work from the master switch using session <switch number>
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_58_se/configuration/guide/3750scg/swstack.html#wp1177242
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Its not working in 3650. please find output below.
Switch#session
% Bad IP address or host name% Unknown command or computer name, or unable to find computer address
Switch#
Switch#
Switch#session ?
% Unrecognized command
Switch#session switch2
% Invalid input detected at '^' marker.
Switch#session 2
Switch#
Switch(config)#session
Switch(config)#
Switch#
Switch#sh sw
Switch/Stack Mac Address : YYYYYY - Local Mac Address
Mac persistency wait time: Indefinite
                                             H/W   Current
Switch#   Role    Mac Address     Priority Version  State
*1       Active   XXX     15     V05     Ready
 2       Standby  XXX     10     V05     Ready
cannot find docu for it,
but maybe this command does not work from a telnet/ssh session, only from the physical consoleport on the active master?
I thought found it!
first you must start TWO remote session to the same switch
then from one of those sessions you can "session #" to a specific member
but this is not correct.
the session command is active on an old stack using c3750-ipbasek9-mz.122-55.SE10.bin
#session ?
  <1-9>  Switch number
but not on a modern stack using Cisco IOS XE Software, Version 16.06.04
#session ?
