3750 backplane connected question
dan.larson
If I have 3 3750 switches connected together with the backplane cables and one of them reboots due to a power glitch, do all of them?
sachinraja
Level 9
Level 9
Not at all. If all the switches are connected to the same power source, they might reboot together.. but one switch going down on a stack will not ramper the stack's performance.... the master/slave relation is recalculated and assigned to the current switch which is up. you can read on the "stacking technology" on the CCO to know more about this...
Hope this helps.. all the best.. rate replies if found useful..
Raj
This is the part that confused me, they all report the same amount of uptime...
When the master moves does the uptime restart?
IOS (tm) C3750 Software (C3750-I9-M), Version 12.1(19)EA1c, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 03-Feb-04 09:20 by yenanh
Image text-base: 0x00003000, data-base: 0x007C887C
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE SOFTWARE (fc1)
HFMA-3750 uptime is 2 hours, 27 minutes
System restarted at 09:59:11 CST Wed Dec 6 2006
System image file is "flash:c3750-i9-mz.121-19.EA1c/c3750-i9-mz.121-19.EA1c.bin"
cisco WS-C3750G-24TS (PowerPC405) processor (revision D0) with 118776K/12288K bytes of memory.
Processor board ID CAT0815N2AD
Last reset from power-on
2 Virtual Ethernet/IEEE 802.3 interface(s)
84 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0F:F7:2C:5E:00
Motherboard assembly number : 73-7058-10
Power supply part number : 341-0045-01
Motherboard serial number : CAT0815089H
Power supply serial number : LIT0813012S
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3750G-24TS-S
System serial number : CAT0815N2AD
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24TS 12.1(19)EA1c C3750-I9-M
2 28 WS-C3750G-24TS 12.1(19)EA1c C3750-I9-M
3 28 WS-C3750G-24TS 12.1(19)EA1c C3750-I9-M
Switch 02
Switch Uptime : 2 hours, 26 minutes
Base ethernet MAC Address : 00:0F:F7:38:61:80
Motherboard serial number : CAT081507GE
Power supply serial number : LIT081300LV
System serial number : CAT0815N3CE
Switch 03
Base ethernet MAC Address : 00:15:C6:32:FD:00
Motherboard assembly number : 73-7058-13
Motherboard serial number : CAT09390T3S
Power supply serial number : PHI0931L0V1
Model revision number : M0
Motherboard revision number : B0
System serial number : CAT0939Z0GS
Configuration register is 0xF
Sure you don't have them all on the same power supply ?
hello larson,
If the master goes out, it does not restrat anything... If it does, there is no use of a technology like stacking.... just go to the child switches and see a "show version" and see the reason for a reboot... if it says the systems restarted by power-on, i guess all these switches are in the same power supply and it is manually rebooted.. take a note of this..
Hope this helps.. all the best. rate replies if found useful..
Raj
