3750 MQC QoS Policy Map not matching packets
kimtoovey
I am trying to setup a simple Policy to Mark Ingress packets to a default of IP Precedence 1. I have a class that matches an ACL to mark packets IP Precedence 0.
Here is basic polic-map I am using to test the basics...
ip access-list standard TEST
permit any
class-map match-any TEST
match access-group name TEST
policy-map TESTMARK
class TEST
  set dscp cs1
I have a Port-Channel with 4 members. Applied the map to the physicals.
fa 1/0/1 - 4
service-policy input TESTMARK
Finding I don't get any hits on the show policy-map i i
FastEthernet1/0/1
  Service-policy input: TESTMARK
    Class-map: TEST (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name TEST
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
FastEthernet1/0/2
      0 packets, 0 bytes
This seems like a basic task however it has me stumped at the moment.
Amit Aneja
Level 3
Level 3
The command 'show policy-map interface ' is not supported on the 3750:
Though visible in the command-line help string, the control-plane and interface keywords
are not supported, and the statistics shown in the display should be ignored.
You would want to use: 'show mls qos interface statistics'
Amit
6 Replies 6
IAN WHITMORE
Level 4
Level 4
This might sound silly, but did you turn qos on?
#mls qos
cadet alain
You won't be able to see the marking like this on a switch. You'll have to sniff on a host receiving traffic or configure an egress ACL on the port connected to destination and match on on dscp with a log option.
Regards.
Alain.
Use "show mls qos interface FastEthernet1/0/1 statistics" to verify.
Alex
Amit Aneja
Level 3
Level 3
Amit
Thanks all for the quick response. I was only looking at these outputs initially and was bothered by the line "qos mode:port-based"
Whilst I have applied the PM to a physical I was wondering if the switch would report on use of MQC.
Switch#sh mls qos interface fa 1/0/1
FastEthernet1/0/1
Attached policy-map for Ingress: TESTMARK
trust state: not trusted
trust mode: not trusted
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
Output of  Switch#sh mls qos interface fastEthernet 1/0/1 statistics
FastEthernet1/0/1 (All statistics are in packets)
  dscp: incoming
  0 -  4 :          39            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
So thanks for pointers. Looks like I was getting the desired result. Now I will be building up the policy to hopefully police CS0's data rate.
If you consider your question is answered please mark it as answered. So that will be helpfull for the others.
Alex
