3750 not handing out IP Addresses
mano.hernandez
We have a 3750 running IOS ver 12.2 (44) SE, it has performed great and we have never had a problem with it. However we have noticed that when we had an outage some of our Wireless APs didn't come up as they get DHCP from the 3750. The DHCP scope said IP was depleted although there were IPs to give. We had to delete and recreate the DHCP Pool. However two days later we got the same problem and then had to do the same thing over again. Any Ideas?
You are getting conflicts in at least two different subnets on this device I see them in both the 192.168.12.X and the 192.168.4.X. The impact these conflicts will have on the subnets will vary greatly depending on: the size of the subnets, the number of clients attempting to obtain addresses, and the order in witch the clients attempt to renew their addresses.
Basically the problem goes as follows:
-The switch hands out addresses and gives: address 1 to client a, address 2 to client b, address 3 to client c, ect...
-The switch reloads and loeses its database, it now has no idea that it has given any address to any client.
-Client d attempts to obtain an IP address, the switch says "lets give him address 1" but then it finds that address 1 is in use (by client a) and says "I will mark that as a bad address and not give that out" it then repeats this process until it finds an address that is not in use, marking everyone it can ping as bad along the way.
-Client a then attempts to renew its IP address, but the switch says " no you can't have that, it's a badd address" and gives it the first good address it has.
Depending on the utilization of the subnet, the switch can end up filling up a whole pool with bad addresses and not have any good ones to hand out. If the utilization is low in the subnet, it may have enough to give everyone a new address on top of the bad addresses and you would not know you have a problem.
8 Replies 8
stephen.stack
Level 4
Level 4
Any specific log entires or errors to go by? What was the output of the following commands?
sh ip dhcp server statistics
sh ip dhcp pool
sh ip dhcp binding
sh ip dhcp conflict
You may also want to run a
deb ip dhcp server events when this issue happens for more verbose logging.
Stephen
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
- Always vote on an answer if you found it helpful
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
Library_3750_L3#sho ip dhcp server statistics
Memory usage         9419
Address pools        2
Database agents      0
Automatic bindings   18
Manual bindings      0
Expired bindings     355
Malformed messages   30
Message              Received
BOOTREQUEST          162818
DHCPDISCOVER         679538
DHCPREQUEST          717559
DHCPDECLINE          204
DHCPRELEASE          7015
DHCPINFORM           791935
Message              Sent
BOOTREPLY            0
DHCPOFFER            16669
DHCPACK              97891
DHCPNAK              887
Library_3750_L3#sh ip dhcp binding
IP address       Client-ID/                      Lease expiration        Type
Hardware address
192.168.4.101    0100.1fca.2843.d8       Jan 12 2013 01:23 PM    Automatic
192.168.4.102    0100.1fca.2844.42       Jan 12 2013 01:23 PM    Automatic
192.168.4.104    0100.1819.bdbb.4a       Jan 12 2013 01:23 PM    Automatic
192.168.4.105    0100.1ae2.531a.82       Jan 12 2013 01:23 PM    Automatic
192.168.4.109    0100.2414.d23f.e8       Jan 12 2013 01:23 PM    Automatic
192.168.4.110    0100.1fca.2844.1c       Jan 12 2013 01:23 PM    Automatic
192.168.4.114    0100.1ae2.5315.de       Jan 12 2013 01:23 PM    Automatic
192.168.4.119    01d4.8cb5.b005.96       Jan 12 2013 01:23 PM    Automatic
192.168.4.120    0100.1aa2.3354.4a       Jan 12 2013 01:23 PM    Automatic
192.168.4.122    01c8.4c75.a989.74       Jan 12 2013 01:23 PM    Automatic
192.168.4.125    0100.1aa2.3350.2c       Jan 12 2013 01:23 PM    Automatic
192.168.4.127    0100.1fca.27e5.0c       Jan 12 2013 01:23 PM    Automatic
192.168.4.128    0100.1fca.2843.78       Jan 12 2013 01:24 PM    Automatic
192.168.4.131    0100.1aa2.3350.38       Jan 12 2013 01:24 PM    Automatic
192.168.4.133    0130.f70d.e65f.d9       Jan 12 2013 01:24 PM    Automatic
192.168.14.95    0100.175a.df7e.81       Jan 12 2013 01:24 PM    Automatic
192.168.14.96    0100.2414.b446.27       Jan 12 2013 01:27 PM    Automatic
192.168.14.97    0100.1759.3f49.87       Jan 12 2013 01:29 PM    Automatic
Library_3750_L3#sh ip dhcp conflict
IP address        Detection method   Detection time
192.168.12.29     Gratuitous ARP     Mar 01 1993 12:11 AM
192.168.12.26     Gratuitous ARP     Mar 01 1993 12:11 AM
192.168.12.75     Ping               Mar 01 1993 12:12 AM
192.168.12.27     Gratuitous ARP     Mar 01 1993 12:12 AM
192.168.12.130    Ping               Mar 01 1993 12:53 AM
192.168.12.131    Ping               Mar 01 1993 12:53 AM
192.168.12.138    Ping               Mar 01 1993 12:54 AM
192.168.12.168    Ping               Mar 01 1993 01:30 AM
192.168.12.187    Ping               Mar 01 1993 03:14 AM
192.168.12.188    Ping               Mar 01 1993 03:14 AM
192.168.12.189    Ping               Mar 01 1993 03:14 AM
192.168.12.190    Ping               Mar 01 1993 03:14 AM
192.168.12.191    Ping               Mar 01 1993 03:14 AM
192.168.12.192    Ping               Mar 01 1993 03:14 AM
192.168.12.193    Ping               Mar 01 1993 03:14 AM
192.168.12.194    Ping               Mar 01 1993 03:14 AM
192.168.12.195    Ping               Mar 01 1993 03:14 AM
192.168.12.196    Ping               Mar 01 1993 03:14 AM
192.168.4.100     Ping               Jan 11 2013 01:23 PM
192.168.4.103     Ping               Jan 11 2013 01:23 PM
192.168.4.106     Ping               Jan 11 2013 01:23 PM
192.168.4.107     Ping               Jan 11 2013 01:23 PM
192.168.4.108     Ping               Jan 11 2013 01:23 PM
192.168.4.111     Ping               Jan 11 2013 01:23 PM
192.168.4.112     Ping               Jan 11 2013 01:23 PM
192.168.4.113     Ping               Jan 11 2013 01:23 PM
192.168.4.115     Ping               Jan 11 2013 01:23 PM
192.168.4.116     Ping               Jan 11 2013 01:23 PM
192.168.4.117     Ping               Jan 11 2013 01:23 PM
192.168.4.118     Ping               Jan 11 2013 01:23 PM
192.168.4.121     Ping               Jan 11 2013 01:23 PM
192.168.4.123     Ping               Jan 11 2013 01:23 PM
192.168.4.124     Ping               Jan 11 2013 01:23 PM
192.168.4.126     Ping               Jan 11 2013 01:23 PM
192.168.4.129     Ping               Jan 11 2013 01:23 PM
192.168.4.130     Ping               Jan 11 2013 01:23 PM
192.168.4.132     Ping               Jan 11 2013 01:23 PM
Library_3750_L3#sh ip dhcp ?
  binding   DHCP address bindings
  conflict  DHCP address conflicts
  database  DHCP database agents
  import    Show Imported Parameters
  relay     Miscellaneous DHCP relay information
  server    Miscellaneous DHCP server information
  snooping  DHCP snooping
Gregory Snipes
Level 4
Level 4
Are you storing the DHCP file in persistent memory? The defualt location for a Cisco device to store its DHCP database is in RAM. When the device reloads it loses the database and you wind up with conflicts as the device trys to hand out IPs that are already in use.
You can move the file with "dhcp database Flash:dhcp.txt"
I am unsure where to look for where the database is stored, but I do know our other DHCP Pool has no problem.
From your output, you definitely have a bunch of conflicts. This strongly supports my theory of what your issue is. I would recommend moving the DHCP file to persistent memory and clearing out the conflicts that have been created with the "clear ip dhcp conflict * " command repeatedly until you stop seeing them.
Can you explain why it is happening to one DHCP Pool and not the other?
This was from TAC
Thanks for your e-mail.
This problems seems to be related to DHCP conflict issue. Let me explain what it is:
Before allocating an ip address to the device requesting for it the router sends an echo request packet to check if the ip address is available. If the router receives ICMP Echo Reply message the address is in use. If the DHCP conflict logging is enabled (default), the router will log the conflict with a syslog message (not in a separate log file) and put the address on the list of conflicts. The addresses on that list (displayed with show ip dhcp conflict) are not used in the future (similar to the addresses configured with the ip dhcp excluded-addresses command). To reuse a conflicting address, we need to remove it from the list with the clear ip dhcp conflict address (or * for all addresses) command.
Cisco recommends disabling the conflict logging by executing the command 'no ip dhcp conflict logging' on the device. This does not affect the DHCP functionality in any way since the server will always ping before allocating an IP address. The only difference would be that if it receives a reply then it will not put that IP in the conflict table and will move on to the next available IP address in the pool and
allocate that if there is no conflict.
As we can see you already have a lot of IP addresses in conflict list:
I would highly recommend you to disable HDCP conflict logging using 'no ip dhcp conflict logging' command. This should fix the issue you are facing. Feel free to revert in case you have any questions for me.
