3750 Stack :: %HLFM-3-SEND_FAIL
Nishant Kumar
We have one 3750 switch stack. One of switch stack is crashing and having some memory leak issues.
Log is giving one message continuously:
switch3750MARWARI#sh log
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 35193 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 181 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 35193 messages logged, xml disabled,
                     filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 70780 message lines logged
Log Buffer (4096 bytes):
nd RPC message,  req 3,  (switch3750MARWARI-2)
-Traceback= 15B4194 1BD86E4 1BD87D8 1BD7B10 1BD7C54 1BD44A8 1BCAF20 (switch3750MARWARI-2)
000186: *Mar  4 06:10:27.757: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000187: *Mar  4 06:10:35.349: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000188: *Mar  4 06:10:40.348: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000189: *Mar  4 06:10:45.474: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000190: *Mar  4 06:11:03.652: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000191: *Mar  4 06:11:08.660: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000192: *Mar  4 06:11:13.668: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000193: *Mar  4 06:11:18.676: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000194: *Mar  4 06:11:23.684: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000195: *Mar  4 06:11:28.893: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
000196: *Mar  4 06:11:34.061: %HLFM-3-SEND_FAIL: Failed to send RPC message,  req 3,  (switch3750MARWARI-2)
Show Version:
switch3750MARWARI#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:59 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
switch3750MARWARI uptime is 3 days, 44 minutes
System image file is "flash:c3750-ipservicesk9-mz.122-55.SE5/c3750-ipservicesk9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1350Y67P
Last reset from power-on
2 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:64:40:46:58:00
Motherboard assembly number     : 73-10219-07
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC13505462
Power supply serial number      : AZS134706FT
Model revision number           : F0
Motherboard revision number     : E0
Model number                    : WS-C3750G-24TS-S1U
System serial number            : FOC1350Y67P
Top Assembly Part Number        : 800-26859-01
Top Assembly Revision Number    : E0
Version ID                      : V03
CLEI Code Number                : CNMWS00ARC
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24TS-1U  12.2(55)SE5           C3750-IPSERVICESK9-M
     2 28    WS-C3750G-24TS-1U  12.2(55)SE5           C3750-IPSERVICESK9-M
Switch 02
Switch Uptime                   : 19 minutes
Base ethernet MAC Address       : 04:FE:7F:7F:3E:00
Motherboard serial number       : FOC14022S9J
Power supply serial number      : DCA1350940U
System serial number            : FOC1401W304
Top assembly part number        : 800-26859-01
Top assembly revision number    : E0
Version ID                      : V03
Configuration register is 0xF
Memory Usage:
switch3750MARWARI#sh processes memory
Processor Pool Total:   68467304 Used:   39790448 Free:   28676856
      I/O Pool Total:   12582912 Used:    8878788 Free:    3704124
Driver te Pool Total:    1048576 Used:         40 Free:    1048536
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   63876272   13764560   36101692          0          0 *Init*
   0   0      13900  272985644      13900          0          0 *Sched*
   0   0  228951376  235575996     541752   11062640    2283560 *Dead*
   1   0  573046884  573330940      69084          0          0 Chunk Manager
   2   0        180        180       4052          0          0 Load Meter
   3   0          0          0      10068          0          0 Connection Mgr
   4   0          0        772       7104          0          0 Check heaps
   5   0     155048    1531436      12696     127944     852268 Pool Manager
   6   0        180        180       7052          0          0 Timers
   7   0          0          0       7052          0          0 Net Input
   8   0          0          0      25052          0          0 Crash writer
   9   0        444        772       7232          0          0 ARP Input
  10   0          0          0       7052          0          0 CEF MIB API
  11   0          0          0       7052          0          0 AAA_SERVER_DEADT
  12   0        180        180       7052          0          0 AAA high-capacit
  13   0          0          0      13052          0          0 Policy Manager
  14   0     789472    2376312     556204          0     451880 Entity MIB API
  15   0          0          0       7052          0          0 IFS Agent Manage
  16   0          0          0       7104          0          0 IPC Dynamic Cach
  17   0          0          0       7052          0          0 IPC Zone Manager
  18   0          0          0       7052          0          0 IPC Periodic Tim
  19   0          0          0       7052          0          0 IPC Managed Time
  20   0          0          0       7052          0          0 IPC Deferred Por
  21   0     219020      12544      32976          0          0 IPC Seat Manager
  22   0          0          0       7052          0          0 IPC Session Serv
  23   0        180        180       7052          0          0 PrstVbl
  24   0          0          0       7052          0          0 Dynamic ARP Insp
  25   0          0          0       7052          0          0 ARP Snoop
  26   0          0          0      13052          0          0 License IPC stat
  27   0          0          0      13052          0          0 License IPC serv
  28   0        180        180       7052          0          0 GraphIt
  29   0        180        180      13052          0          0 XML Proxy Client
  30   0          0          0       7052          0          0 Critical Bkgnd
  31   0     357776       1800      13460          0          0 Net Background
  32   0          0          0      13052          0          0 IDB Work
  33   0     159784        180      26352     101520          0 Logger
  34   0        180        316      10052          0          0 TTY Background
  35   0  109020096    2138300      66100    9157104          0 Per-Second Jobs
  36   0      66560        200       7052      42300          0 Per-minute Jobs
  37   0     113472     152180      73968          0          0 IF-MGR control p
  38   0          0          0       7052          0          0 IF-MGR event pro
  39   0      33120      33120      10052          0          0 IP Admission HA
  40   0        180        180       7052          0          0 Compute load avg
  41   0          0          0       7052          0          0 AggMgr Process
  42   0          0     139884       7052          0          0 Transport Port A
  43   0          0          0       7052          0          0 HC Counter Timer
  44   0          0          0       7052          0          0 SFF8472
  45   0        180        180       7052          0          0 DownWhenLooped
  46   0          0          0       7052          0          0 HULC PBR Tcam Me
  47   0          0          0       7052          0          0 HULC ACL Tcam Me
  48   0          0          0       7052          0          0 HRPC hdwl reques
  49   0          0          0       7052          0          0 HRPC EnergyWise
  50   0          0          0       7052          0          0 HRPC actual powe
  51   0          0          0       7052          0          0 HRPC lpip reques
  52   0        180        180       7052          0          0 HLPIP Sync Proce
  53   0          0          0       7052          0          0 HRPC Multi-FS Sy
  54   0      27196      23416       7052          0          0 HULC multifs pro
  55   0          0          0       7052          0          0 HRPC hnetwpol re
  56   0          0          0       7052          0          0 Hulc Warm Upgrad
  57   0          0          0       7052          0          0 HRPC ipadm reque
  58   0        180        180       7052          0          0 SM RBCP Monitor
  59   0          0          0       7052          0          0 HULC QM Tcam Mem
  60   0          0          0       7052          0          0 Hulc EEM Process
  61   0      34148   41176972      43600          0          0 EEM ED ND
  62   0       4904          0      14956          0          0 EEM ED Identity
  63   0       4980          0      15032          0          0 EEM ED MAT
  64   0          0          0       7052          0          0 Hulc LED Alchemy
  65   0          0          0       7052          0          0 HRPC asic-stats
  66   0  482429328  877388716       7052          0          0 RedEarth Tx Mana
  67   0   42680892   85402752       7052          0          0 RedEarth Rx Mana
  68   0      72996        180       7052          0          0 HULC Thermal Pro
  69   0          0          0       4052          0          0 HRPC hsm request
  70   0          0          0      13052          0          0 Stack Mgr
  71   0    4202164    2774732     600184      35532          0 Stack Mgr Notifi
  72   0       5616        180      12544          0          0 Fifo Error Detec
  73   0        576        576       4052          0          0 Adjust Regions
  74   0       7368 2508019080       7052       1560 1594613556 hrpc -> response
  75   0          0          0       7052          0          0 hrpc -> request
  76   0 1411610900 2832571460      12372   21080628   20676240 hrpc <- response
  77   0        628        628       7052          0          0 HRPC hcomp reque
  78   0       5588       1392       7060          0          0 HULC Device Mana
  79   0     724944     516864      96276      63012          0 HRPC hdm non blo
  80   0       1552       1552       7052          0          0 HRPC hdm blockin
  81   0          0          0      13052          0          0 HIPC bkgrd proce
  82   0          0          0       7052          0          0 RTTYS Process
  83   0      41956      34676       7052          0          0 Hulc Port-Securi
  84   0      11624      11624       7052          0          0 HRPC hpsecure re
  85   0 1962017016 4035578608     121024 1407950424          0 HRPC hlfm reques
  86   0 1119661900        180      12372   55704024          0 HLFM address lea
  87   0        180        180       7052          0          0 HLFM aging proce
  88   0        180        280       7052          0          0 HLFM address ret
  89   0          0          0      13052          0          0 HRPC hrcmd reque
  90   0          0          0       7052          0          0 HRPC emac reques
  91   0       2900       2900       7052          0          0 HRPC hulc misc r
  92   0          0          0       7052          0          0 HULC Tcam Memory
  93   0          0          0      13052          0          0 HVLAN main bkgrd
  94   0        180        180       7052          0          0 HVLAN Mapped Vla
  95   0        180        180       7052          0          0 Vlan shutdown Pr
  96   0   33429352    2388116      23012   19740564          0 HRPC vlan reques
  97   0          0          0       7052          0          0 HULC VLAN REF Ba
  98   0        180        180       7052          0          0 hulc_xps_process
  99   0          0          0       7052          0          0 HRPC isis reques
100   0       4184       2252       7052          0          0 HRPC hfbm reques
101   0    1356708     316912       7080      91368          0 HCMP sync proces
102   0      17080      17080       7052          0          0 HRPC ilp request
103   0          0          0       7052          0          0 HULC PM Vector P
104   0          0          0       7052          0          0 HPM Msg Retry Pr
105   0          0          0       7128          0          0 MDFS LC Download
106   0   13956296    4841820     749164          0          0 hpm main process
107   0    1352516    1144080       7052      10152          0 HPM Stack Sync P
108   0    3466368    3316564      38104      50760          0 HRPC pm request
109   0      36256      30676       9096          0          0 HPM if_num mappi
110   0   77796776   30327716       7052      10152          0 hpm counter proc
111   0  348331372  341561044       7052    4304448          0 HRPC pm-counters
112   0          0          0       7088          0          0 hpm vp events ca
113   0          0          0       7052          0          0 HRPC hcmp reques
114   0          0          0      13052          0          0 HCEF ADJ Refresh
115   0          0          0       7052          0          0 HRPC hl3mm reque
116   0          0          0       4052          0          0 hl3md_rpfq_thrl_
117   0      93888      93888       7052          0          0 hl3mm
118   0          0          0       7052          0          0 hl3mm_rp
119   0          0          0       7052          0          0 HACL Queue Proce
120   0          0          0       7052          0          0 HRPC acl request
121   0      19108     253084      61052          0          0 HACL Acl Manager
122   0          0          0       7052          0          0 HRPC backup inte
124   0          0          0       7052          0          0 HRPC cdp request
125   0          0          0       7052          0          0 HRPC lldp reques
126   0          0       5444       7052          0          0 HULC CISP Proces
127   0      63112      22760       7052          0          0 HRPC dot1x reque
128   0          0          0       7052          0          0 Dot1X Msg Retry
129   0      94688     548844       7052          0          0 HULC DOT1X Proce
130   0          0          0       7052          0          0 HRPC foxhound re
131   0        472        180       7344          0          0 Hulc Foxhound Pr
132   0       1400       1400       4052          0          0 HRPC system mtu
133   0          0          0       7052          0          0 SMI MSG Retry Pr
134   0          0          0      10052          0          0 HRPC Smart Insta
135   0          0          0       7052          0          0 HRPC sdm request
136   0        180        180       7052          0          0 Hulc Storm Contr
137   0        180        180       7052          0          0 HSTP Sync Proces
138   0          0          0       7052          0          0 HRPC stp_cli req
139   0          0          0       7052          0          0 HRPC stp_state_s
140   0        180        180       7052          0          0 S/W Bridge Proce
141   0       3316       3316       7052          0          0 HRPC hudld reque
142   0          0          0       7052          0          0 HRPC vqpc reques
143   0          0          0       7052          0          0 BCM cable diags
144   0          0          0       7092          0          0 HRPC iec_load_ba
145   0          0          0       7060          0          0 HRPC l2pt qnq rp
146   0          0          0       7052          0          0 HRPC aim request
147   0        180        180       7052          0          0 MACsec Process
148   0          0          0       7052          0          0 HRPC macsec requ
149   0     250288     234328       7052      10152          0 HRPC hled reques
150   0  393844388        180      10116          0          0 Hulc LED Process
151   0       2404          0      13052          0          0 HL3U bkgrd proce
152   0   10889820    8023508       7052    1822284          0 HRPC hl3u reques
153   0          0          0      61052          0          0 HL3U PBR bkgrd p
154   0          0          0       7052          0          0 HL3U PBR n-h res
155   0          0          0       7052          0          0 HRPC dtp request
156   0          0          0       7052          0          0 HRPC show_forwar
157   0          0          0       7052          0          0 HRPC snmp reques
158   0          0          0       7052          0          0 HULC SNMP Proces
159   0 2095123552 2037527404      77436   26192160          0 HQM Stack Proces
160   0 2104714924 2104714924      61052          0          0 HRPC qos request
161   0          0          0       7052          0          0 HRPC span reques
162   0          0          0       7052          0          0 HRPC obfl reques
163   0     145140     124348      10416          0          0 HRPC system post
164   0      29668      15888       7052          0          0 Hulc Reload Mana
165   0   11319228   11311248       7052       5076          0 HRPC hrcli-event
166   0          0          0       7088          0          0 DHCPD Timer
167   0        180        180      10052          0          0 image mgr
168   0          0          0       7052          0          0 HRFS OIR Proc
169   0        180        180       7052          0          0 Power RPS Proces
170   0   29446860   29231408     379304          0          0 HL2MCM
171   0   28433620   28219268     376232          0          0 HL2MCM
172   0        180        180       7052          0          0 PI MATM Aging Pr
173   0      81352          0      88404          0          0 Switch Backup In
174   0          0          0       7052          0          0 MMN bkgrd proces
175   0        180        180      13052          0          0 Auth Manager
176   0        180        180       7052          0          0 Dot1x Mgr Proces
177   0          0          0       7052          0          0 MAB Framework
178   0          0          0       7052          0          0 AUTH POLICY Fram
179   0          0          0       7052          0          0 CMD HANDLER
180   0          0    1182672       7052          0          0 802.1x switch
181   0        180        180       7052          0          0 802.1x MDA Aging
182   0          0          0       7052          0          0 802.1x Webauth F
183   0     658128     259888     304656          0          0 DTP Protocol
184   0          0          0       7052          0          0 EAP Framework
185   0          0          0       7052          0          0 EAP Test
186   0          0          0       7052          0          0 HRPC dai request
187   0          0          0       4052          0          0 HULC DAI Process
188   0          0          0       7052          0          0 HRPC ip device t
189   0          0          0       7052          0          0 HRPC ip source g
190   0          0          0       7052          0          0 HULC IP Source g
191   0        472        180       7344          0          0 UDLD
192   0        216          0       7268          0          0 Port-Security
193   0        180        180      10052          0          0 IP Host Track Pr
194   0          0          0       7052          0          0 Link State Group
195   0        180        180       7052          0          0 Ethchnl
196   0  321841108 2380698820    2138296   16172136          0 VMATM Callback
197   0        180        180       7052          0          0 CDP Forward Proc
198   0      12880        392      19540          0          0 MKA
199   0        180        180       7052          0          0 AAA Server
200   0          0          0       7052          0          0 AAA ACCT Proc
201   0          0          0       7052          0          0 ACCT Periodic Pr
202   0          0          0       7064          0          0 AAA System Acct
203   0          0          0       7052          0          0 Auth-proxy AAA B
204   0          0          0       7052          0          0 IP Admin SM Proc
205   0  119311464   47043856      33244    5592060          0 CDP Protocol
206   0          0          0       7164          0          0 DiagCard2/-1
207   0          0          0       7052          0          0 HRPC x_setup req
208   0        204        204       7052          0          0 AAA Dictionary R
209   0          0          0       7052          0          0 DHCP Snooping
210   0        396        180      13268          0          0 CEF switching ba
211   0    1378340     845976      15828          0          0 IP Input
212   0          0          0       7052          0          0 ICMP event handl
213   0        180        180      10052          0          0 IP ARP Track
214   0          0          0       7052          0          0 IPv6 ping proces
215   0        180        180      13052          0          0 MDFS MFIB Proces
216   0        396        180      13268          0          0 ADJ resolve proc
217   0        396        180       4268          0          0 ADJ NSF process
218   0    2622104     850960       7600       2268          0 SpanTree Helper
219   0       3140       5008      28192          0          0 SMI Director DB
220   0          0          0       7052          0          0 SMI CDP Update H
221   0        680          0      25732          0          0 SMI Backup Proce
222   0       3988        180      10860          0          0 SMI IBC server p
223   0        420          0      13472          0          0 SMI IBC client p
224   0       4832        180      17704          0          0 SMI IBC Download
225   0 4239564072      17340      24716     129276          0 Spanning Tree
226   0          0          0       7052          0          0 Spanning Tree St
227   0        180        180      10052          0          0 EAPoUDP Process
228   0        180        180      13052          0          0 KRB5 AAA
229   0       2060        180      14932          0          0 SXP CORE
230   0        396        180      13268          0          0 CEF background p
231   0          0          0      10052          0          0 IP IRDP
232   0          0          0       7052          0          0 CEF RF HULC Conv
233   0     104092       8736      21872          0          0 XDR mcast
234   0        180        180       7052          0          0 IP ACL XDR LC Ba
235   0      51932          0       7052          0          0 IPC LC Message H
236   0          0          0       7052          0          0 XDR RP Ping Back
237   0     183656     213144       7052          0          0 XDR RP backgroun
238   0          0          0       7052          0          0 XDR RP Test Back
239   0       7540        180      13284          0          0 MDFS LC Process
240   0      15488     145440      13052          0          0 TCP Timer
241   0     299372          0      13052          0          0 TCP Protocols
242   0          0          0       7052          0          0 Socket Timers
243   0  251447208  225522852      41616          0          0 HTTP CORE
244   0        180        180       7052          0          0 Cluster L2
245   0          0          0       7052          0          0 Cluster RARP
246   0    9804172    9801868       9356          0          0 Cluster Base
247   0          0          0       7052          0          0 RARP Input
248   0          0          0       7052          0          0 Critical Auth
249   0        396        180       7268          0          0 Dot1x Supplicant
250   0        396        180       7268          0          0 Dot1x Supplicant
251   0        396        180       7268          0          0 Dot1x Supplicant
252   0          0          0       7052          0          0 HRPC dhcp snoopi
253   0       8972       3072       7052          0          0 HULC DHCP Snoopi
254   0          0          0       7052          0          0 HRPC stack power
255   0    2141964 3518370752    1224040          0          0 IGMPSN L2MCM
256   0          0          0       7052          0          0 IGMPSN MRD
257   0          0          0       7052          0          0 IGMPSN
258   0          0          0       7052          0          0 IGMPQR
259   0      15052        180      11856          0          0 L2TRACE SERVER
260   0    2194276 3513202656    1322856          0          0 MLDSN L2MCM
261   0          0          0       7052          0          0 MRD
262   0          0          0       7052          0          0 MLD_SNOOP
263   0          0          0       7052          0          0 HRPC hwccp reque
264   0          0          0       7052          0          0 HULC_WCCP_BACKGR
265   0      31096       1732      27044          0          0 crypto engine pr
266   0        216          0      10268          0          0 IP RIB Update
267   0      40080        204      38748          0          0 DHCPD Receive
268   0   51908580    5158736      57596   29730132          0 HRPC hl2mcm igmp
269   0  253801532          0       7052          0          0 MDFS RP process
270   0   33672908    5097164      38972   18172080          0 HRPC hl2mcm mlds
271   0        216          0       7308          0          0 DHCPD Database
272   0          0          0       7052          0          0 EPM MAIN PROCESS
273   0        180        180       7052          0          0 LOCAL AAA
274   0        180        180       7052          0          0 ENABLE AAA
275   0        180        180       7052          0          0 LINE AAA
276   0 2331152672 1519642320       7088          0          0 SpanTree Flush
277   0       2060        180       8932          0          0 TPLUS
278   0     532288     526056      15284          0          0 Crypto CA
279   0          0          0       9052          0          0 Crypto PKI-CRL
280   0          0          0       9052          0          0 Crypto SSL
281   0          0          0       7052          0          0 encrypt proc
282   0       4832       9184      11704          0          0 VTP Trap Process
283   0        180        180       7052          0          0 VTPMIB EDIT BUFF
284   0        180        180       7052          0          0 DHCP Security He
285   0          0          0       7068          0          0 HCD Process
286   0          0          0       7052          0          0 HRPC cable diagn
287   0        132        348       7052          0          0 DiagCard1/-1
288   0     395748    1338988      17804          0          0 PM Callback
289   0     234148     272752      15060       2340          0 VLAN Manager
290   0       8900          0      34028          0          0 LICENSE AGENT
291   0        180        180       7052          0          0 dhcp snooping sw
292   0          0          0      10052          0          0 Licensing MIB pr
293   1      10272       1896      21428          0          0 Virtual Exec
294   0        180        180       7052          0          0 AAA SEND STOP EV
295   0       9684          0      19736          0          0 EEM ED Routing
296   0     232872          0     242924      99792          0 EEM ED Syslog
297   0          0          0       7052          0          0 Syslog Traps
298   0   14366516   14366516      13052          0          0 Syslog
299   2      30344      21904      21500          0          0 Virtual Exec
300   0     173108          0     180160          0          0 EEM Server
301   0      13240       1668      18624          0          0 EEM Policy Direc
303   0       4980          0      15032          0          0 EEM ED CLI
304   0       4904          0      14956          0          0 EEM ED Counter
305   0       4904          0      14956          0          0 EEM ED Interface
306   0       4904          0      14956          0          0 EEM ED IOSWD
307   0       4904          0      14956          0          0 EEM ED None
308   0       4904          0      14956          0          0 EEM ED OIR
309   0      91084      70476      11312          0          0 SSH Event handle
310   0       5056          0      15108          0          0 EEM ED SNMP
311   0       4904          0      14956          0          0 EEM ED SNMP Obje
312   0       4904          0      14956          0          0 EEM ED Ipsla
313   0       4904          0      14956          0          0 EEM ED SNMP Noti
314   0       5208          0      15260          0          0 EEM ED Timer
315   0        180        180       4052          0          0 STP FAST TRANSIT
316   0        180        180       4052          0          0 CSRT RAPID TRANS
317   0       4904          0      14956          0          0 EEM ED RPC
318   0        600        384      13268          0          0 RBM CORE
319   0       7204       2932      13064          0          0 hulc cfg mgr mas
320   0   34581596   34597280      10068          0          0 crypto sw pk pro
321   0          0          0       7104          0          0 hulc running con
322   0      16948       3356       9172          0          0 OBFL Cfg Dispatc
                                 48509936 Total
switch3750MARWARI#sh processes memory sort
switch3750MARWARI#sh processes memory sorted
Processor Pool Total:   68467304 Used:   39670552 Free:   28796752
   0   0  228951376  235576200     541752   11062640    2283560 *Dead*
159   0 2095202280 2037605476      77436   26192160          0 HQM Stack Proces
  35   0  109024888    2138376      66100    9157104          0 Per-Second Jobs
160   0 2104796188 2104796188      61052          0          0 HRPC qos request
  61   0      34148   41178068      43600          0          0 EEM ED ND
205   0  119312788   47044084      33244    5592060          0 CDP Protocol
299   2      44804      26152      31712          0          0 Virtual Exec
  86   0 1119702588        180      18600   55704024          0 HLFM address lea
211   0    1378340     845976      15752          0          0 IP Input
   0   0      13900  272992772      13900          0          0 *Sched*
  76   0 1411629116 2832647684      12372   21080628   20676240 hrpc <- response
150   0  393866292        180      10116          0          0 Hulc LED Process
246   0    9804400    9802096       9356          0          0 Cluster Base
152   0   10889988    8023676       7052    1822284          0 HRPC hl3u reques
111   0  348345364  341575036       7052    4304448          0 HRPC pm-counters
110   0   77800184   30329156       7052      10152          0 hpm counter proc
  67   0   42683404   85407724       7052          0          0 RedEarth Rx Mana
  66   0  482459052  877442632       7052          0          0 RedEarth Tx Mana
269   0  253808864          0       7052          0          0 MDFS RP process
  42   0          0     139960       7052          0          0 Transport Port A
                                 48526300 Total
I am also getting MALLOC ALLOCATION FAILURE messages.
Please help.
Regs
Nishant
p.mcgowan
Level 3
Level 3
traceback errors are generally very bad news, usually an IOS failure.
you could take time to troubleshoot the problem, quickest solution would be to upgrade or downgrade your IOS
Hi McGowan,
Which IOS version you recommend to upgrade/downgrade?? ... How about 12.2(55)SE4 ??
Also note, that only one switch of stack if creating issues, other one doesn't has any issues although both running same IOS.
Thx
Nishant
