3750 switch locking up issue
c.walsh
Level 3
Level 3
We have a customer with a stack of 2 x 3750x-24P switch's running IOS 12.2(58)SE1 feature set  C3750E-IPBASEK9-M.
They report that all devices lose connectivity & that the only way to resolve the issue is to reboot the stack.
Has anyone seen this before, is it possibly a bug with the IOS.
Colin
7 Replies 7
IAN WHITMORE
Level 4
Level 4
It could be...or it could be something not configured correctly on the switches.
Would be good to see the config. It could be spanning-tree of course if it's not configured correctly or a number of other things like broadcast storms etc.
We would need to see logs, configs etc to have a better indication. Provide us with what you can.
HTH,
Ian
The logs were cleared when the switch was rebooted.
config...
version 12.2
no service pad
hostname XXXXXXX
boot-start-marker
boot-end-marker
enable secret XXXXXXXX
username xxx privilege 15 password 0 yyyyyy
no aaa new-model
switch 1 provision ws-c3750x-24p
switch 2 provision ws-c3750x-24p
system mtu routing 1500
ip routing
ip dhcp excluded-address 192.168.250.129
ip dhcp excluded-address 192.168.250.254
ip dhcp excluded-address 192.168.250.1 192.168.250.4
ip dhcp excluded-address 192.168.250.253
ip dhcp excluded-address 192.168.250.252
ip dhcp excluded-address 192.168.250.200
ip dhcp pool Voice
   network 192.168.250.0 255.255.255.128
   default-router 192.168.250.1
   option 150 ip 192.168.210.1 192.168.34.2
   domain-name xxxxx.local
   dns-server 192.168.100.140 192.168.100.142
ip dhcp pool Data
   network 192.168.250.128 255.255.255.128
   default-router 192.168.250.252
vtp mode transparent
mls qos map policed-dscp  0 10 18 24 46 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
crypto pki trustpoint TP-self-signed-4270496768
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4270496768
revocation-check none
rsakeypair TP-self-signed-4270496768
crypto pki certificate chain TP-self-signed-4270496768
certificate self-signed 01
  30820244 308201AD A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34323730 34393637 3638301E 170D3933 30333031 30303031
  32375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32373034
  39363736 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CFA6 E52A650C 84ED05B0 DF9136ED 5230380A 78C7BAB9 DAB3D93B DDF2040F
  82D34E4F A6FD7190 864DFEEA 0B6DE6DC 5ACA198B 1BB71B8C 5C66CD1C A59D87EA
  487CA6CC E569914E 1F848137 72E53EFF A5185518 696E7B89 136088E5 6E730429
  9F1CD323 3F85DBAA C077E078 C4AFB052 3D96EE92 1ADB861C 002886A3 D953CAE9
  AD3F0203 010001A3 6C306A30 0F060355 1D130101 FF040530 030101FF 30170603
  551D1104 10300E82 0C52494E 5F333735 305F5357 49301F06 03551D23 04183016
  8014A289 9272F054 4DF7E329 C4D5AB0A 5902F9AA 7B5C301D 0603551D 0E041604
  14A28992 72F0544D F7E329C4 D5AB0A59 02F9AA7B 5C300D06 092A8648 86F70D01
  01040500 03818100 93A14230 BD779E81 866CF43A D8437886 5A1B04D9 13DFF432
  82F2EF6E F6A6326D 2DEAB806 DD9FBE8D 5DDE60D4 AC1E28B0 E9249567 F292EA51
  A54871C0 31B75CB8 0DBFD687 B2624BDC F15694A0 7B80C68D B22B960D F9FCA506
  AC11D1E2 5253CA07 F5ED85BA A80E3CFA 380238B8 87B58C78 CD11DDDE BE2C1BE4
  BBC65238 0B2FDDCF
      quit
license boot level ipbase
license boot level ipbase switch 1
spanning-tree mode pvst
auto qos srnd4
vlan internal allocation policy ascending
vlan 2
name Voice
vlan 10
class-map match-all AUTOQOS_VOIP_DATA_CLASS
  match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
  match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
  match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
   set dscp ef
  police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
   set dscp cs3
  police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
   set dscp default
  police 10000000 8000 exceed-action policed-dscp-transmit
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
description *** Video Conferencing ***
switchport mode access
duplex full
srr-queue bandwidth share 1 30 35 5
srr-queue bandwidth shape 10 0 0 0
priority-queue out
mls qos trust cos
auto qos trust
interface GigabitEthernet1/0/23
description *** MPLS WAN ***
switchport access vlan 10
priority-queue out
mls qos trust cos
auto qos trust
interface GigabitEthernet1/0/24
description *** DSL RTR Fallback ***
interface GigabitEthernet2/0/1
description Link to Voice Gateway
switchport access vlan 2
mls qos trust dscp
interface GigabitEthernet2/0/2
switchport voice vlan 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
all other ports configured the same as g2/0/2
interface Vlan1
ip address 192.168.250.252 255.255.255.128
interface Vlan2
description Voice
ip address 192.168.250.1 255.255.255.128
interface Vlan10
description *** BT MPLS ***
ip address 192.168.6.5 255.255.255.248
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.6.1
ip access-list extended AUTOQOS-ACL-DEFAULT
permit ip any any
logging esm config
line con 0
line vty 0 4
password xxxxxx
login local
length 0
line vty 5 15
login
Can't see anything obvious in the config.
Checked the bugs as well for this model/version and there are only 43, none relating to this.
Can you provide also:
#sh spann
#sh int status
#sh int trunk
#sh cdp nei
and before the next reload, try and get a look at the logs. Also, do they say how often this occurs?
Might be best to put it all in a text file and attach.
Ian
ankugarg
Level 3
Level 3
Is this happening consistently or happened only once...Also try to get the output of "sh logging",i addition to what Ian pointed.
Can you paste the output of show spanning-tree detail | i ieee|from|occur|is exec?
This ouptut will indicate from where we received the TCN's.
What is the cpu utlization of the switch?
++ Enable mac flap notification, so that in case of any loops in the network, we can figure it out.
conf t
mac address-table notification mac-move.
Hope this helps
Cheers
Somu
Rate helpful posts
Here is the link for troubleshooting common issues in 3750 switch.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00807ccc79.shtml
Hope this helps
Cheers
Somu
Rate helpful posts
Leo Laohoo
Have you tried shut/no shut all the ports?
