3750 Switch Stack
G3261
Level 7
Level 7
here is my scenario....I have 5 3750 switches stacked (1-5) and i want to remove switch 2 (slave). What would be the best way doing this WITHOUT any reboots?  Can I just remove switch 2 and then switch 3 will becomes slave? Is there any election process stack will do for slave? I don't want my stack to reboot. Thanks
It should not reboot other switches.
Pawan Raut
Level 10
Level 10
The next switch which has higher priority in member become slave automatically. Make sure that you should have ring topology for stack.
Kindly rate for helpful post
Thanks for your reply...
any reboots happen during this change? I will change the stack cables configuration after I shutdown the switch.
thanks a lot
