3750 upgrade
RekaNemar
Hello Friends,
I am about to upgrade a 3750 , what’s the best version to go for. I am 12.2 (25). Is it ok to jump from (25) to (55) ipservices.
second question , after I copied the image file to flash: do I need to create a ‘boot system’ command to load the new image file. If so what’s the command please.
What's the model number?  There are a few different models and IOS versions.  Jumping from 12.2(25)SE to 12.2(55) won't be an issue.
You shouldn't really just use the .bin file.  Get the .tar file and use the 'archive download-sw' command as this will configure the boot parameters for you and copy the HTML files for the GUI management.
Hi Andy,
model WS-3750G-48TS standalone mode
According to the release notes the WS-3750G-48TS supports 12.2(58)SE1 and later releases.  You can therefore upgrade this to 15.0(2)SE11.  It is the same image for the 3750V2 series.  This is the final release for this switch as its EoL.
Leo Laohoo
Upgrade to 15.0(2)SE11.
