3750 vs 3650 QOS Bandwidth Limitation
JHaynes4B
When configuring QOS on the 3750 switch the following message is displayed when looking at the queueing configuration of an interface;
Shaped queue weights (absolute) : 25 0 0 0
Shared queue weights : 1 30 35 5
The port bandwidth limit : 100 (Operational Bandwidth:100.0)
The port is mapped to qset : 1
This is even though the port is gigabit.
My question is does the 3650 switch switch have the same limitation? I do not see anywhere to view the information on the port.
Thanks.
I think you can view that information with the command (change the interface as you see fit):
3650G#sh mls qos interface gi 0/7 queueing
The 3850 and 3650 moved away from the mls commands:
WS-C3850-48T#sh mls ?
% Unrecognized command
Reza Sharifi
What command produced this output on a 3750?  I don't see the same command on the new 3650 series.
Actually, I think the command I mentioned is available on the 3750 and the 3850 in Denali:
sh mls qos interface gi 0/1 queueing
GigabitEthernet0/1
Egress Priority Queue : enabled
Shared queue weights : 10 10 60 20
The port is mapped to qset : 2
