Bookmark
Subscribe
12435
3750-X Netflow
Carl Williams
I need Serious help, basically I have netflow which i'm trying to use to export to a netflow collector. I'm pretty sure that the 3750-X does support netflow. I've recently updated IOS on the 3750-X to support flexi netflow.
For some reason the netflow packets are not being exported to the server.
I'm using Opmanager which should present the netflow stats in the form of a graph.
I'm using a universal IOS image.
(C3750E-UNIVERSALK9-M), Version 12.2(58)SE2
3750-X WS-C3750X-24T-S
(config-if)#$itor PERIVALE_NETFLOW_MONITORING input
% Flow Monitor: Flow Monitor 'PERIVALE_NETFLOW_MONITORING' This image doesn't support Flexible Netflow!
UB6-G40-PV102-3750CX(config-if)#$itor PERIVALE_NETFLOW_MONITORING output
Which IOS supports netflow, baring in mind that I need a full feature set.
configs below
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet1/0/21
ip flow-export version 9
ip flow-export destination 10.173.66.143 9996
No packets being exported to my server
show ip flow export
Flow export v9 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       10.118.0.106 (GigabitEthernet1/0/21)
    Destination(1)  10.173.66.143 (9996)
  Version 9 flow records
  0 flows exported in 0 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
Any ideas?
12 Replies 12
You will need to add :
ip flow ingress
ip flow egress
on the interfaces/SVI that you want.
example :
int vlan 53
ip flow in
ip flow eg
Dan
Can you add it to a physical interfaces.
What should the total command output be.
Ports I want to export netflow from.//
GigabitEthernet2/0/21
TenGigabitEthernet1/1/2
TenGigabitEthernet2/1/2
Yes you can add it to a physical interface. You will add "ip flow ingres" "ip flow egress" on all ports that you what to export.
interface rang gi1/0/21 , gi2/0/21
ip flow eg
ip flow in
interface rang ten1/1/2 , te2/1/2
ip flow eg
ip flow in
If you have traffic on those ports, you can check with :
show ip cache flow | b Src
Dan
show ip cache flow
IP packet size distribution (0 total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 278544 bytes
  0 active, 4096 inactive, 0 added
  0 ager polls, 0 flow alloc failures
  Active flows timeout in 1 minutes
  Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 33608 bytes
  0 active, 1024 inactive, 0 added, 0 added to flow
  0 alloc failures, 0 force free
  1 chunk, 1 chunk added
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP  Pkts
Inactive flows mate i'm getting./////
Still not exporting..//
show ip flow export
  VRF ID : Default
Could you paste the relevant config.
Later edit :  also show licence
In order to use netflow you must have IP base or IP services licence . Not lan base.
Dan
//// This is applied but not used
flow exporter export-to-Perivale-Comvault_Server
transport udp 9996
flow record PERIVALE_MONITORING
match datalink mac source address input
match datalink mac source address output
match datalink mac destination address input
match datalink mac destination address output
match ipv4 version
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow monitor PERIVALE_NETFLOW_MONITORING
netflow version 9 config
int GigabitEthernet1/0/21
ip flow ingress
ip flow egress
int GigabitEthernet2/0/21
ip flow ingress
ip flow egress
interface TenGigabitEthernet1/1/2
ip flow ingress
ip flow egress
interface TenGigabitEthernet2/1/2
ip flow ingress
ip flow egress
license in use.
show license
Index 1 Feature: ipservices
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
Index 2 Feature: ipbase
        License State: Active, Not in Use
Index 3 Feature: lanbase
        Period left: 0  minute  0  second
jakewilson
Hi Carl,
We posted a blog on configuring NetFlow on the 3750X with the 3KX module.  Without the 3KX module the only NetFlow you can get from the switch is Smart Logging Telemetry exports. I hope this helps.
Scrutinizer NetFlow Analyzer supports both.
Good luck.
C3KX-NM-10G thats the module i'm using. Using opmanager netflow to gather stats.
I think that the problem netflow support on this platform.
URL_1 :
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/prod_white_paper0900aecd80406232.html
Device
Supported
Cisco 800, 1700, 2600
Yes
Cisco 1800, 2800, 3800
Yes
Cisco 4500
Yes
Cisco 6500
Yes
Cisco7200, 7300, 7500
Yes
Cisco 7600
Yes
Cisco 10000, 12000, CRS-1
Yes
Cisco 2900, 3500, 3660, 3750
No
URL_2 :
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_58_se/release/notes/OL24338.html
NetFlow Commands
Unsupported Global Configuration Commands
ip flow-aggregation cache
ip flow-cache entries
ip flow-export
mikek
You need the Service Module (C3KX-SM-10G). That module contains specific silicon for Netflow and macsec. The nom doesn't.
